cliking
Old Dec 20, 2005 | 07:37 AM
accordredliner's Avatar
* B A N N E D *
Default cliking
my car clicks only when I turn and accelerate. I know that axle is a possible cuprit but if so shouldn't my car clicks even without acceleration?
Old Dec 20, 2005 | 08:07 AM
P_Adams's Avatar
Default Re: cliking (accordredliner)
You're putting a heavier load on the CV Joint while accellerating. If it just started making noise, this isn't uncommon.
P
Old Dec 20, 2005 | 08:16 AM
YeuEmMaiMai's Avatar
your CV joints need to be inspected to make sure that the boots are not cracked. IF the boots are cracked replace the joint if you can otherwise replace the axle. When you start hearing noise, it's too late...........
Old Dec 20, 2005 | 08:17 AM
maroonaccord2.2's Avatar
CV joint in half-shaft..... Either needs <U>rebuild</U> or replace with new part.
Old Dec 21, 2005 | 08:14 PM
* B A N N E D *
Default Re: cliking (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">You're putting a heavier load on the CV Joint while accellerating. If it just started making noise, this isn't uncommon.
P</TD></TR></TABLE>
thanks, that explains it.
tundra2000
Apr 8, 2011 11:54 AM
riceforlife
Suspension & Brakes
13
Dec 12, 2007 11:27 PM
BB6racer
Jul 21, 2005 09:24 PM
redwinqs
Feb 5, 2004 04:24 PM
sutrusu
Jun 16, 2003 01:05 PM
