Whats the A/R ratio of this housing
I have a turbo netics exhaust housing. I am trying to determine the A/R of it.
It has two part numbers cast on it. Both are on oppiste sides of the turbo flange. One is in larger numbers then the other.
The larger # is 20357 .48
The small # is 20358 .63
I am not sure why there are 2 different #'s.
Also there is not a .48 or .63 engraved on the inside.
Here are a few pics
Here are a few pics
Take a picture of the entire housing from the outlet side, that'll help to guess which stage wheel it has also.
The fact that it has 2 unique id numbers on it though... is wierd. Give Turbonetics a call when they open up.
(I suspect its the 20357, but have nothing to back this up... just a hunch
I think....
There are two versions of the 20357 and a few of the 20358.
20357-02 = .48a/r stg2 whl
20357-03 = .48a/r stg3 whl
20358-72 = .63a/r std trim
20358-02 = .63a/r stg2 whl
20358-03 = .63a/r stg3 whl
To me it looks to be a .63a/r turbine housing..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00STFREAK »</TD></TR><TR><TD CLASS="quote"> I think....
To me it looks to be a .63a/r turbine housing..</TD></TR></TABLE>
.48
Stage I Standard 20357-1
Stage II Standard 20357-2
Stage III Standard 20357-3
Stage V Standard 20357-5
.63
Stage I Standard 20358-1
Stage II Standard 20358-2
Stage III Standard 20358-3
Stage V Standard 20358-5
Is off the Turbonetics site.
.48
.63
That isn't the stage 5, I actually just sold one and it would have less material around the flange area. So I can help narrow it down some at least.
it definately is a turbonetics housing. check the inside of the inlet of the housing for a number. there should be stamping on it. might be covered with a whole bunch of carbon.
EDIT: if you have a set of calipers, measure the space it has for the turbine and it will give you an idea of what stage it might be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostdummy »</TD></TR><TR><TD CLASS="quote">I did and nothing there
Possibly ported then. I'd give turbonetics a call during the day, and ask.
</TD></TR></TABLE>Possibly ported then. I'd give turbonetics a call during the day, and ask.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostdummy »</TD></TR><TR><TD CLASS="quote">Anybody else have any idea's?</TD></TR></TABLE>
Once again... call them
Get an email from them and send the pics... they are your best bet at this point.
I called them and they don't know the a/r o fit either
Apparently its an "old" housing and they don't have the a/r on file anymore for any housings with 2 different part numbers on them
