93 integra rear discs fit on 96-00 civic?
Old Dec 20, 2005 | 06:12 AM
willyboyK20's Avatar
Default 93 integra rear discs fit on 96-00 civic?
I was wondering if the rear disc conversion from a 1993 integra would work on my 97 civic. I have the opprotunity to get a pair pretty cheap. I was just wondering if it would work.
Old Dec 20, 2005 | 06:17 AM
Slowboy!'s Avatar
Im pretty sure they will. I would go for it.
Correct me if im wrong guys. Either way I would still buy them for cheap and sell them for more.
Curt
Old Dec 20, 2005 | 06:55 AM
Targa250R's Avatar
be professional
Default Re: 93 integra rear discs fit on 96-00 civic? (willyboyD16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willyboyD16 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if the rear disc conversion from a 1993 integra would work on my 97 civic. I have the opprotunity to get a pair pretty cheap. I was just wondering if it would work.</TD></TR></TABLE>
Yes.
Old Dec 20, 2005 | 07:15 AM
Default Re: 93 integra rear discs fit on 96-00 civic? (Targa250R)
thanks for the replies. So it simply bolts up with no modifcations?
Old Dec 20, 2005 | 07:57 AM
hatchi's Avatar
you might need different ebrake cables
Old Dec 20, 2005 | 11:07 AM
Targa250R's Avatar
be professional
Get the following from the Integra: hub assemblies, rotors, calipers, soft lines. Trailing arms are optional (the hub assemblies are held onto them by Torx bolts). Do not use any other arms from the Integra.
You will need to buy new e-brake cables for a '99-00 Civic Si.
If the rotors look okay and are well above minimum thickness spec, you can have them cut on a brake lathe and reuse them. If they're no good, scrap them and buy new ones. Buy new brake pads if you cut or replace the rotors.
You could optionally turn in the calipers as cores for some re-manufactured calipers to avoid any potential problems with those.
I am not sure if the soft lines from the Integra will fit. Try them out, and if they don't fit, then order some for a '99-00 Civic Si - because you need soft lines for a car with rear discs since the fitting for a caliper vs. a wheel cylinder is different.
Old Dec 20, 2005 | 02:41 PM
Uncle Jesse
Jul 23, 2007 02:16 PM
oxmark4
Sep 27, 2006 07:24 AM
93 CX HB
Jan 12, 2005 04:35 PM
dan310
Dec 30, 2004 08:48 AM
