clutch problem
Old Dec 20, 2005 | 02:38 AM
f150harleytruck7's Avatar
Default clutch problem
i just swapped out my d16z6 for a jdm zc sohc in my 95 civic coupe. I installed a exedy stage 1 clutch and a 7lb fidenza flywheel and the clutch is releasing at the very bottom, i noticed that the old clutch didnt have a pilot bearing, but my kit came with one and i installed it, could this have caused the pedal difference or can i adjust it out or is it caused my the flywheel and i just have to get use to it? i do have a hydraulic clutch also thanks, anything else i need to do to this motor?
Old Dec 20, 2005 | 03:23 AM
Lonely's Avatar
Default Re: clutch problem (f150harleytruck7)
did you try bleeding your clutch or adjusting pedal height?
Old Dec 20, 2005 | 03:59 AM
Default Re: clutch problem (methodman4o8)
i havnt got a chance yet, but i never cracked open the clutch lines hen i did the motor, but i guess that new clutch might change it, the old engine didnt have a pilot bearing, but my kit came with one, so i installed it behind the new flywheel, maybe it dosnt need that bearing?
supadupafast
May 16, 2015 06:47 AM
EternalHour
Jan 11, 2013 10:21 AM
an2ny888
Transmission & Drivetrain
Sep 7, 2010 08:58 PM
lswantsvtec
Jun 25, 2007 09:37 PM
danny98r
Jun 24, 2004 12:15 PM
