Wastegate spring question
Im kinda in a hurry..a friend of mine has an HKS 40mm Wastegate..could he put the 10 lbs Tial spring in there? sorry if its a retarded question.
are the springs the same size in diameter and height? If so, then I wouldn't see why not....just as long as the dimensions are the same then it would essentially be the same type spring, just with a different spring rate.
