using a plasma cutter
Old Dec 19, 2005 | 09:58 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Default using a plasma cutter
i just got a used thermal dynamic plasma cutter and this will be the 1st time ever using one. im just going to cut some scrap metal for now to play with. when cutting do i put the tip on the metal or hold it back some. is it like a MiG how you can burn the tip to the metal if holding it to close ?
Old Dec 19, 2005 | 10:07 PM
DvD3's Avatar
B A N N E D
Default Re: using a plasma cutter (1QwIkEf)
it cuts close, it wont touch because by the time u try to touch it itll cut it lol. play around with it have fun
Old Dec 19, 2005 | 10:12 PM
rjay8604's Avatar
Default Re: using a plasma cutter (DvD3)
Sweet, make a video of it cutting, those things are awesome. I wanna see it in action.
Old Dec 19, 2005 | 10:15 PM
weiRtech's Avatar
OG Fabricator
depending on your settings and how thick the material is, you will be close to it, but not touching it. you should be able to get finger tips that go on over the existing nozzle tip that acts as a touch finger for how close you should be. once you get it setup up properly and get used to it it will be just like a hot knife through warm butter.
Old Dec 20, 2005 | 04:02 AM
Want2race's Avatar
Default Re: (weirRacing)
I hold the nozzle against the material.
It gives cleaner cuts and tips are cheap!
Old Dec 20, 2005 | 08:32 AM
1QwIkEf's Avatar
Default Re: (Want2race)
ok thax for the info
Tjabo
Welding / Fabrication
23
Feb 29, 2016 11:11 AM
turbotime
18
Jan 29, 2007 08:01 PM
LostAndFound
Dec 14, 2006 12:36 PM
RCautoworks
18
Sep 30, 2005 11:38 AM
koolmoedee5
Dec 18, 2004 08:38 PM
