curious swap question??
Old Dec 19, 2005 | 09:37 PM
EF_9's Avatar
Default is it ok to use??
hey guys wassap i just got a ls obd-0 swap and the people used my stock ecu pm6 on it is that ok?
will it be faster and better if i use the pr4 obd-0 ecu???
thanks guys
oh yeah they also used my sohc si dizzy on it too is that ok also???
Modified by EF_9 at 10:47 PM 12/19/2005
Modified by EF_9 at 10:51 PM 12/19/2005
Old Dec 19, 2005 | 09:48 PM
SD_Lurker's Avatar
HT White Ops
Default Re: curious swap question?? (EF_9)
I dont think it will make much of a difference. I suggest that you get a program for your ecu and it will be fine.
crxnj's Avatar
Think about it..1.8L dual cam motor run by an ecu made for a 1.6L single cam..
You need the pr4 for the motor to run right..Or you could chip the stock ecu with ls fuel/timing maps
Old Dec 19, 2005 | 09:49 PM
EF_9's Avatar
will the pr4 obd-0 be fine??
Old Dec 19, 2005 | 09:50 PM
crxnj's Avatar
Default Re: (EF_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_9 &raquo;</TD></TR><TR><TD CLASS="quote">will the pr4 obd-0 be fine??</TD></TR></TABLE>
Yeah..It plugs up and everything if that's what you're asking
Old Dec 19, 2005 | 09:52 PM
EF_9's Avatar
dang it!!
how bad will the car run cuz i dont have the pr4 right now
Old Dec 19, 2005 | 10:03 PM
crxnj's Avatar
Default Re: (EF_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_9 &raquo;</TD></TR><TR><TD CLASS="quote">dang it!!
how bad will the car run cuz i dont have the pr4 right now</TD></TR></TABLE>
It will run lean and not to it's full potential..
Greyknight1138
Engine Management and Tuning
Mar 10, 2014 05:00 AM
90crxef
Apr 1, 2008 10:02 AM
strawberry
10
Dec 14, 2007 11:47 AM
ef9robert
12
Oct 5, 2006 09:50 AM
altoid
Jul 23, 2003 07:06 AM
