Drag III Turbo for Civic Si 99 ( URGENT )
Old Mar 17, 2002 | 10:45 AM
CiViC SiR's Avatar
Default Drag III Turbo for Civic Si 99 ( URGENT )
Hi everyone i want to buy a drag III turbo full kit, what do i have to buy in additional to get nice proformance and keep every running smothlly ?
thanx
Old Mar 17, 2002 | 10:54 AM
shawnhayes's Avatar
Default Re: Drag III Turbo for Civic Si 99 (CiViC SiR)
thanx
My $0.02:
A Hondata stage IIIB with 440cc RC Engineering injectors (of course, you'd have to convert it to OBDI, as well)
Shawn
[Modified by shawnhayes, 7:55 PM 3/17/2002]
Old Mar 17, 2002 | 11:42 AM
DragII's Avatar
25 Year Member
Default Re: Drag III Turbo for Civic Si 99 (shawnhayes)
Drag supplies everything you need for low boost applications.
Old Mar 17, 2002 | 11:49 AM
CiViC SiR's Avatar
Default Re: Drag III Turbo for Civic Si 99 (SuperDragII)
i want to increase the boost to 12
Old Mar 17, 2002 | 02:57 PM
HXMan's Avatar
This is the list I have for myself. Drag 3 kit on 99 b16a2. Oh, since you don't have hondata yet, might as well add $1000 to the price I got down there!
This is the setup I will be using for 6-8 psi daily, maybe 10 at the track.
Part: Price: Quanity Needed:
Fuel System
450cc Eclipse Injectors Set of 4 $50.00 1
Flow Balance and Cleaning Injectors $100.00 1
Greddy Fuel Pressre Guage $235.00 1
Resistor Box (from early honda) $30.00 1
Wiring Accessories $20.00 1
AEM Fuel Rail #25-103 $125.00 1
AEM FPR #25-300 $145.00 1
Walbro 255LPH Pump $150.00 1
Sub Total $855.00
Oil Return Line
10 AN 45 degree swivel fitting #804610 $28.29 2
1/2" to 10 AN #98160 $4.97 1
10 AN Steel Weld fitting #????? $5.50 1
10 AN hose $9.18 2
Sub Total $85.41
Misc.
ClutchNet Stage 2 $350.00 1
Hondata Boost Upgrade $345.00 1
Greddy EGT Guage $180.00 1
Turbo XS MBC #TXS-SBC $79.95 1
Cluster Bezel #ATM-20010 $69.95 1
Sub Total $1,024.90
Total $1,965.31
Notes on prices:
FPR, Fuel Rail http://www.importhorizon.com
AN line and fittings http://www.anplumbing.com
MBC, Cluster Bezel http://www.summitracing.com
Old Mar 17, 2002 | 03:06 PM
DragII's Avatar
25 Year Member
on stock internals??
eh...have fun
w/ hondata, you still shouldn't exceed 10psi on stock stuff.
Old Mar 17, 2002 | 03:32 PM
TurboSedan's Avatar
New User
I know you are being safe saying not to go over 10Psi on the Hondata with stock internals, but what do you base that Psi rating on? From what I have seen, that setup should run with no problems at all at 12Psi granted it is professionally tuned.
Old Mar 17, 2002 | 03:41 PM
DragII's Avatar
25 Year Member
Default Re: Drag III Turbo for Civic Si 99 (97CivicFerio)
can, and should are two differant things....even w/ hondata....12psi is really pushing it. you may run 12 @ the track for a run or two, but run that on the street daily, and see how long your ring lands last.
don't forget the B16 has 10.2 compression.
I have the above set up, and I'm not going over 11 even at the track.
Old Mar 17, 2002 | 09:34 PM
deepnite's Avatar
Default Re: Drag III Turbo for Civic Si 99 (HXMan)
a bud was only running 6lb boost and didnt have all that..and he end d up with a whole blown thru the header and a bunch of internal bleeding
Old Mar 17, 2002 | 10:32 PM
builthatch's Avatar
MiG-21 superfan
aem unit, 440's and Harv tuning it on the dyno....also upgrade to a tial wastegate, get a turbo xs dual stage, Walbro, or if you like paying more money for the same thing, holley, 255 fi fuel pump and get a percy's egt monitor or a good egt gauge and cross your fingers. those cast piston ring lands WILL NOT LAST on 12 psi, regardless of tuning.
[Modified by builthatch, 7:35 AM 3/18/2002]
Old Mar 18, 2002 | 12:52 AM
CiViC SiR's Avatar
ok tell me what do think about these stuff..
-JE low comp. pistons
-Block guard
-stage 2 clutch
-Full drag III kit
-MSD
Old Mar 18, 2002 | 01:15 PM
DragII's Avatar
25 Year Member
don't lower compression too much...stay close to stock....block guard is pretty worthless....clutchnet Stage II clutch is awesome....MSD is not necisarry, I have a friend running 10s on stock ignition.
Old Mar 18, 2002 | 02:08 PM
CheezeFrog's Avatar
How about 20psi on a stock B18B w/block guard on pump gas.
https://honda-tech.com/zerothread?id=138345
Old Mar 18, 2002 | 02:32 PM
DragII's Avatar
25 Year Member
Default Re: Drag III Turbo for Civic Si 99 (CheezeFrog)
I have a friend running 25psi, on an FMU, and VAFC, on a stock B18c running 10 second quartermiles....does that mean I think it's good avice for the rest of the world?
*shakes head*
Old Mar 18, 2002 | 05:29 PM
.nate's Avatar
I have a friend who had the clutchnetstage 2, and it was fine on his turbo hatch till he put slicks on it... then it started slipping...
Old Mar 18, 2002 | 05:48 PM
DragII's Avatar
25 Year Member
Default Re: Drag III Turbo for Civic Si 99 (TheFLY)
hmm....I haven't run slicks on mine yet...It feels great on the street though....I'll see how it feels on slicks next month
Old Mar 18, 2002 | 06:00 PM
DR. ON POINT's Avatar
Banned
my clutchnet stage 2 chatters a lot, but it is also fairly new...if I had to do it again I dont know if I would...i drove a gsr with a clutchmasters stage 4 and it felt realy good....I need more time and miles to tell though..more power as well
Old Mar 18, 2002 | 06:02 PM
DragII's Avatar
25 Year Member
Default Re: Drag III Turbo for Civic Si 99 (On Point EK)
you should have resurfaced your flywheel, and changed out the pilot bearing mang....mine doesnt chatter at all.
Old Mar 18, 2002 | 06:03 PM
redteg1's Avatar
12lbs is no joke..on stock internals
Old Mar 18, 2002 | 06:13 PM
Banned
flywheel was perfect..no heat marks....and pilot bearing looked fine as well....I replaced the release bearing...its still not bad.....its just not stock.....gotta get use to it
turbo Si
Aug 19, 2002 03:59 PM
AB16A2T
Apr 23, 2002 12:39 PM
philo
Dec 30, 2001 07:36 AM
