dizzy problems
Old Dec 19, 2005 | 05:58 PM
si0385.'s Avatar
Default dizzy problems
i have a d15b i just bought the car and somebody used the obd0 dizzy... i tired adjusting the ignition timming but i cant turn it... i heard somewhere that if i grind off the two bottom lobes on the dizzy (that dont have bolts in them anyways because they dont line up) that i can turn the dizzy and adjust the ignition timing
can anybody confirm this before i go grinding away at my distributor???
Old Dec 19, 2005 | 07:03 PM
si0385.'s Avatar
Default Re: dizzy problems (jaydeum4lyfe)
Old Dec 19, 2005 | 07:07 PM
dr_latino999's Avatar
You should be able to turn it the way it is, what I would look into is extending the openings of the bolt holes, not wacking them off, that way you can actually use more then one bolt to hold it on.
Old Dec 19, 2005 | 07:20 PM
si0385.'s Avatar
Default Re: dizzy problems (dr_latino999)
the lobes and the threaded holes are completley off even if i extended the holes i couldint put a bolt in them i will try to get a pic in a little bit
Old Dec 20, 2005 | 07:43 PM
si0385.'s Avatar
anybody else ?
apaige58
Mar 24, 2014 10:16 AM
EkChuck
Dec 1, 2012 07:50 AM
Fuster_Cluck
10
Feb 24, 2005 09:58 AM
85civic
Aug 14, 2004 12:27 PM
SI_niki
Jun 15, 2004 11:34 AM
