Fan Switch
Old Dec 19, 2005 | 04:35 PM
Linh.'s Avatar
Default Fan Switch
Reading other peoples threads are confusing me. I just want to know how i can run a fan switch on my car when the vehicle turns on. Should i run it with a inline fuse and would a 15a fuse? Would the coolin fan relay need to be used?
Old Dec 22, 2005 | 11:16 PM
Linh.'s Avatar
Default Re: Fan Switch (shooitslinh)
Tried to make install a fan switch today. I bought a universal relay but there are 5 pins on them and they are postive,negative, fuse, and two lamps. Everything has power to it. My question is am i wiring it correctly? Do the two lamp pins go to the fan. Where should i wire my fuse pin? And am i supposet to fuse it.
Old Dec 23, 2005 | 11:29 AM
Linh.'s Avatar
i know someone can help me out here
Old Dec 23, 2005 | 11:36 AM
94hatchling's Avatar
you dont need a relay to wire up a switch for the fan. at least i didnt. i'm just using the factory fuse for the fan. if no one beats me to it, i'll post up again saying how. at work, will post up later.
Old Dec 24, 2005 | 07:11 AM
Linh.'s Avatar
Default Re: (94hatchling)
i did a switch but m fuse keeps blowing
killaberna
Sep 14, 2015 10:06 AM
Linh.
Dec 24, 2005 08:50 AM
4DRmafia
Sep 1, 2004 02:59 PM
dingusjt
Jul 15, 2002 10:40 AM
