d15b2???
Old Dec 19, 2005 | 03:15 PM
crxnonvtec's Avatar
Default d15b2???
so Im told the d15b2 has the same head as the d16a6 is that true in all aspects. also y use the y8 cam gear. also if I did decide to go with a mpfi swap would I just need to add the injectors, wiring and ecu from a d16a6 or would I need the harness I was just wondering if that ecu plugged right in. Sorry for being long winded I only get five posts a day and its hard to ask questions that way. any help?
Old Dec 19, 2005 | 03:46 PM
Redline130's Avatar
Default Re: d15b2??? (crxnonvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxnonvtec &raquo;</TD></TR><TR><TD CLASS="quote">so Im told the d15b2 has the same head as the d16a6 is that true in all aspects. also y use the y8 cam gear. also if I did decide to go with a mpfi swap would I just need to add the injectors, wiring and ecu from a d16a6 or would I need the harness I was just wondering if that ecu plugged right in. Sorry for being long winded I only get five posts a day and its hard to ask questions that way. any help?
You don't need to use a Y8 cam gear on either head. If you want to do a MPFI conversion, you will need a MPFI intake manifold, the injectors, and a PM6 ecu. You can then add the necessary wiring to complete the conversion. Do not attempt to try and use the Si wiring harness, it will only give you more headaches.
Old Dec 19, 2005 | 03:54 PM
mattie_96's Avatar
by y8 you are referring to the cam gear to use when you do the full si swap (a6 cam)......I was told the a6 cam gear and d15b2 ones are the same and will work but the y8/y7 one is more accurate for timing.
Can anyone please clarify because im also changing to an a6 cam soon.
THanks
Old Dec 19, 2005 | 06:24 PM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: (mattie_96)
The casting is the same, but the cam, and maybe valve springs are not.
Old Dec 20, 2005 | 04:04 AM
crxnonvtec's Avatar
Default Re: d15b2??? (Redline130)
so I can use my stock harness and it will plug into that ecu and I can use either an a6 or y8 cam gear?
Old Dec 20, 2005 | 04:11 AM
crxnonvtec's Avatar
I still need more detailed info on the d15b2 but no one has it because everyone is so hung up on engine swaps. I need all the real detailed stuff. anyone help please this project needs to get started.
Old Dec 20, 2005 | 04:12 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxnonvtec &raquo;</TD></TR><TR><TD CLASS="quote">so I can use my stock harness and it will plug into that ecu and I can use either an a6 or y8 cam gear?
-Yes..You use your stock harness and convert it to multi point injection.
Here's a link to a nice write-up Fourthgenhatch.com
What detailed info do you need?
Old Dec 20, 2005 | 04:18 AM
crxnonvtec's Avatar
anything valve sizes deck height crank journal size anyhting like that. thanks Ill check that out
Old Dec 20, 2005 | 05:25 AM
crxnonvtec's Avatar
does anyone know the pin size and rod journal sizes?
Old Dec 20, 2005 | 06:14 AM
Civiclized's Avatar
the head casting is the same.Valves and clearance on them are different.The cams are different, the gears, and the dizzy's. Also the Si harness would be a needed. Iv've heard that you can re-pin the ecu on a DX DPFI and I have a print out of how to-but guys around here say other wise.best bet is to get some specs and do yyur homework
the rod journals have two different sizes that you will only know for shure once you tear it down to get a number off the crank, but if you give me a year, make, and , model, i can look it up at work and get you some specs....
Modified by Civiclized at 7:25 AM 12/20/2005
projectpd
11
Oct 16, 2011 02:31 PM
*i<3MyCiViC*
11
Aug 23, 2010 08:11 AM
vtec_crx
Apr 2, 2010 02:52 PM
CRXguy_88
11
Mar 1, 2010 03:47 AM
darowdyest
Nov 18, 2009 11:30 AM
