When car is running, suddendly it feels like it's on Neutral, what it can be?
Old Dec 19, 2005 | 02:16 PM
Starscream's Avatar
Default When car is running, suddendly it feels like it's on Neutral, what it can be?
Well my friend has a 95 LX auto Accord, and he tells me that he's driving it normally on the street, then the car suddendly feels like it's on neutral, he floors and the revs climb, but the car doesn't accelerate.
If he shuts the car down, and turn it up again, the glitch is gone and everything is back to normal for a while, before showing up again.
What could it be?
Old Dec 19, 2005 | 03:00 PM
BLKFLSH's Avatar
Default Re: When car is running, suddendly it feels like it's on Neutral, what it can be? (Starscream)
Is the D light, in the dash display, on when it souldn't be (when in park or neutral). If so, you may have a computer problem. If not maybe tourqe converter or transmission. Checked the condition, level of the fluid?
Old Dec 19, 2005 | 03:01 PM
wingback44's Avatar
Default Re: When car is running, suddendly it feels like it's on Neutral, what it can be? (BLKFLSH)
its probably something to do with the transmission. my girlfriends parents had the same problem on the explorer. it kept neutralling out in reverse.
Old Dec 19, 2005 | 03:48 PM
iam7head's Avatar
um sounds like the auto tranny is slipping pretty bad.
Old Dec 19, 2005 | 04:48 PM
LiViNgLeGeNd's Avatar
Default Re: When car is running, suddendly it feels like it's on Neutral, what it can be? (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">um sounds like the auto tranny is slipping pretty bad.
yep. this same thing happened to my civic. kept happening till one day i was going up a hill and it just redlined, tranny was gone for good. try changing the auto tranny fluid. that helped the slips a little bit on my legend.
Old Dec 20, 2005 | 08:47 AM
hondadude's Avatar
the description you give is classic "plugged up sump" I'll bet the torque converter clutches are coming apart and there is lots of debris in the trans, it plugs up the fluid pick up point then the trans has no pressure; when you let the car sit for 10-15 minutes the junk falls out of the pick up and the trans again has pressure.
Drop the trans open the case and clean it all out, get a new torque converter and drive it some more
Old Dec 20, 2005 | 09:33 AM
YeuEmMaiMai's Avatar
Default Re: When car is running, suddendly it feels like it's on Neutral, what it can be? (hondadude)
rebuild the trans if the TQ converter has come apart otherwise you are gonna have to do it soon anyways and sending metal though a new TQ converter is a bad idea
Old Dec 20, 2005 | 11:52 AM
fishwgoose's Avatar
it's def. the tranny. My friends acura was doing that. He had to replace the chip in the engine and he had to replace the trans. valves. It shouldn't cost you too much, if you do it yourself around 100bucks, take it to a dealer a lot more good luck
moopsguitar
Jun 19, 2008 05:49 PM
Exempt
Dec 22, 2006 03:05 PM
deeweezy187
May 26, 2006 04:07 AM
Deemeetree
Sep 28, 2004 08:14 PM
BlackE36
Aug 14, 2003 09:02 AM
