rear brake piston not compressing all the way
Old Dec 19, 2005 | 01:10 PM
shutta's Avatar
Default rear brake piston not compressing all the way
the e-brake isn't on, i turn the adjuster in so far it starts turning back 1/10th ish turn when i stop and don't tough it. i need that extra 1/8"ish to get the damn thing over the rotor. what should I do?
i think i'm going to pull off the ebrake cable and see if that is messing it up at all.. it might be jammed since the car hasn't driven in 2 years. i used it a few times but i'm thinking when i let off the e-brake it doesn't let off all the way. any ideas if that doesn't work?
thanks
Old Dec 19, 2005 | 01:44 PM
prelittlelude's Avatar
Default Re: rear brake piston not compressing all the way (shutta)
hard to tell from your post, but you do know that the rear brake caliper piston screws in. the e brake everytime you pull it takes up some slack by unscrewing the piston.. you need to screw it in.
Old Dec 19, 2005 | 07:50 PM
Ross 2.0's Avatar
In a Junkyard near you.
The easiest way is to use this
http://www.chain-auto-tools.com/pics/AMR450L.jpg
But prelittlelude is right you have to turn the piston back into the caliper. It won't press in.
Old Dec 19, 2005 | 08:00 PM
kornerk12's Avatar
Default Re: (MooGoCow3)
What is tht called and where can i buy one?
Old Dec 20, 2005 | 07:28 AM
i just used a big flat head screw driver, the piston had slots in it,
Old Dec 20, 2005 | 07:32 AM
shutta's Avatar
Default Re: (kornerk12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 &raquo;</TD></TR><TR><TD CLASS="quote">What is tht called and where can i buy one? </TD></TR></TABLE>
yeah, what exactly is that? yes I know it turns in. I turn it so i have about 1/16" left sticking out, and if i turn it any more than that it gets hard to turn and when i let go it turn back slightly so there is still the 1/16" sticking out. it's liek there is some force keeping it from going all teh way in. the spring from the e-brake is disconnected and at the e brake line I have as much slack as I can get without pulling the assembly off teh caliper. the pins were being a bitch so I figured taking the spring off woudl work... yes the main brake line is off also.
Old Dec 20, 2005 | 07:45 AM
mgags7's Avatar
you will need to get your testes together and wrench that **** down....its obviously a bit jammed from sitting....
you may want to pull the boot off and just rebuild the caliper while youre in there....
Old Dec 20, 2005 | 07:48 AM
Default Re: (shutta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, what exactly is that? yes I know it turns in. I turn it so i have about 1/16" left sticking out, and if i turn it any more than that it gets hard to turn and when i let go it turn back slightly so there is still the 1/16" sticking out. it's liek there is some force keeping it from going all teh way in. the spring from the e-brake is disconnected and at the e brake line I have as much slack as I can get without pulling the assembly off teh caliper. the pins were being a bitch so I figured taking the spring off woudl work... yes the main brake line is off also.</TD></TR></TABLE>
well it should screw all the way down, sack it up and screw it down... just put some muscle into it. heh
Old Dec 20, 2005 | 07:51 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta &raquo;</TD></TR><TR><TD CLASS="quote">it's liek there is some force keeping it from going all teh way in. </TD></TR></TABLE>
but tom....its the force, the force has got it....argh....
WRENCH THAT BIOTCH DOWN Y0! oh yeah and righty-tightey...lol....
Old Dec 20, 2005 | 09:02 AM
shutta's Avatar
but when i let go of it, it just spins back.. i'll give it some elbow grease tonight
Old Dec 20, 2005 | 09:06 AM
mgags7's Avatar
it is odd that it spins back...but let us know how it goes
Old Dec 20, 2005 | 09:13 AM
shutta's Avatar
yeah, i just didn't want to twist it real hard and expletive something up.
how important are those metal shims that come on the back side of the pads? i coudl ditch those and have enough room..
Old Dec 20, 2005 | 09:14 AM
BlueLude94's Avatar
Default Re: (mgags7)
I know a little trick is to use the old pad and pry it against the piston...but in this case it may not work, in that case I use a c-clamp and a flat piece of metal.
Old Dec 20, 2005 | 09:15 AM
mgags7's Avatar
Default Re: (BlueLude94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude94 &raquo;</TD></TR><TR><TD CLASS="quote">I know a little trick is to use the old pad and pry it against the piston...but in this case it may not work, in that case I use a c-clamp and a flat piece of metal.</TD></TR></TABLE>
rear calipers screw in dude....
Old Dec 20, 2005 | 09:48 AM
AzCivic1.6's Avatar
is the boot all caught up and twisted? making it want to spin back out.
Old Dec 20, 2005 | 10:48 AM
Ross 2.0's Avatar
Spray some wd-40 or any other spray lubricant and spray it on the boot. That'll keep it from sticking.
Old Dec 20, 2005 | 10:49 AM
Ross 2.0's Avatar
Please save us some work. If you don't know what your doing please don't even try to give advice...
Old Dec 21, 2005 | 07:54 AM
shutta's Avatar
i'll try the wd-40.. hwo exactly is that boot held inside the caliper? does anyone have a diagram from helms or whatever? i've misplaced mine..
scartail
Aug 1, 2010 04:58 PM
Sam268
Aug 25, 2003 09:03 AM
flybert
Feb 9, 2003 04:25 PM
ken
Jul 3, 2002 08:00 PM
