Help, 93 civic will crank but will not start.
Old Dec 19, 2005 | 01:01 PM
raczyk's Avatar
Default Help, 93 civic will crank but will not start.
This morning i get into my car in a rush to get to work, but my car just cranks. It does not want to start. It seems it is at the virge of starting, but there seems to be some irregularities to the firing of the spark plugs. So I have replaced all the spark plugs. I can hear the fuel pump pumping. Any ideas?
Old Dec 19, 2005 | 02:24 PM
EKJUNKY80's Avatar
Default Re: Help, 93 civic will crank but will not start. (raczyk)
did you check for spark?
Old Dec 19, 2005 | 02:31 PM
raczyk's Avatar
Default Re: Help, 93 civic will crank but will not start. (EKJUNKY80)
I have not checked the spark, do you have any detail info on how to do this. Just sounds odd running the car with no spark on all the cylinders.
Old Dec 19, 2005 | 02:33 PM
djfob's Avatar
I had a hairline crack in my dizzy that caused these symptoms
Old Dec 19, 2005 | 02:54 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raczyk &raquo;</TD></TR><TR><TD CLASS="quote">I have not checked the spark, do you have any detail info on how to do this. Just sounds odd running the car with no spark on all the cylinders.
Pull off one spark plug wire, stick a spark plug in it, ground it, and have someone crank the engine.
Old Dec 19, 2005 | 03:05 PM
1995Ex_Sedan's Avatar
Pull out a spark plug wire, stick a screw driver in it, and ground it somewhere, or hold the spark plug wire against the valve cover and have someone crank it. Look for the spark.
I had my car just completely shut off while driving because of a bad/old dizzy. It'd do the same thing. Stupid question, but did you check the battery?
Old Dec 19, 2005 | 03:24 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (1995Ex_Sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Ex_Sedan &raquo;</TD></TR><TR><TD CLASS="quote">Stupid question, but did you check the battery?</TD></TR></TABLE>
That is a stupid question seeing as he said it would crank and try to start
Old Dec 19, 2005 | 03:48 PM
Pfft. Its been a long day.
Old Dec 19, 2005 | 04:01 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Ex_Sedan &raquo;</TD></TR><TR><TD CLASS="quote">Pfft. Its been a long day. </TD></TR></TABLE>
Have a and chill
95sirek4
Sep 2, 2011 07:35 PM
slk08
May 20, 2009 11:09 AM
FunStuff
Aug 1, 2007 03:15 AM
vinuneuro
Oct 3, 2006 01:26 PM
skata89
May 21, 2006 03:32 PM
