Emissions Test.
Old Dec 19, 2005 | 12:15 PM
mistawho's Avatar
Default Emissions Test.
I passed my emissions test when the 3 days before i had a CEL on and it said my cataylist converter is deteriorating.... I just reset the code.. drove.... and retried my emissions test.... and i passed!!!! And they said nothing is wrong with me car???
Old Dec 19, 2005 | 12:37 PM
notoriousB's Avatar
Default Re: Emissions Test. (mistawho)
horray!
that's how I pass emissions in my turbo'd accord, install stock ECU/injectors/MAP sensor, drive around for a little bit, take test, pass, remove all crap & reinstall aftermarket stuff. good for another year. It throws a code if I drive too long w/ stock stuff I just get the test done before the code appears.
Old Dec 19, 2005 | 01:19 PM
P_Adams's Avatar
If your car is OBD2b equipped, there can (from time to time) be conditions whereas the 2nd position O2 sensor is out of range (either because of a heater issue or momentary contamination). this sometimes happens when the secondary O2 sensor doesn't agree with the front (primary) O2 sensor (or isn't seeing the values it's expecting.
P
Old Dec 19, 2005 | 03:23 PM
brads94accord's Avatar
awesome, the guy who passed me last year got busted so im gonna try the spark plug no fouler trick w/ my secondary 02 sensor to see i f pass this year, im gonna have to disconnect the wastegate flapper and put my stock 0bd2 ecu and injectors back in to pass this year. i hope i have the same luck you do, anyone know the approximate drive cycle on the accord ecus? i was reading on the civics its only warm up from complete cool, then let the car cool off again, then drive to the emissions place.
Old Dec 20, 2005 | 04:30 AM
notoriousB's Avatar
Default Re: (brads94accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord &raquo;</TD></TR><TR><TD CLASS="quote">im gonna try the spark plug no fouler trick w/ my secondary 02 sensor to see i f pass this year</TD></TR></TABLE>
that trick works awesome, I've personally installed it on a few people's cars and it always works. I'll be doing the same when I have my cat removed next month.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord &raquo;</TD></TR><TR><TD CLASS="quote">anyone know the approximate drive cycle on the accord ecus? i was reading on the civics its only warm up from complete cool, then let the car cool off again, then drive to the emissions place.</TD></TR></TABLE>
you definitely need to start the car at least 3 times before the codes are all set. This last time I reset the computer leaving work on a friday, drove it home, then the next morning I just drove around doing errands for an hour or two and then went & passed the test no problem.
Old Dec 20, 2005 | 09:01 AM
cool im glad it works.. a lot of guys seemed to like it on s2k forums. i don't have anywhere to install a cat on my car the guy who did my exhuast just did it straight back w/ one section
j.bro
Honda Civic (2001 - 2005)
Mar 31, 2011 11:36 AM
Iomega01
Aug 31, 2005 10:54 PM
Chris_Bye
May 1, 2005 07:56 AM
sslude
Mar 21, 2003 01:22 PM
jpaik
Dec 10, 2002 03:52 PM
