i know this is messed up, but what do i need ?
Old Dec 19, 2005 | 10:29 AM
MOVE OVER's Avatar
Default i know this is messed up, but what do i need ?
picture should say it all.
what fuse is this supposed to be ?
which one is for the ecu ? i need to reset it because its throwing a atmospheric pressure sensor code.
Old Dec 19, 2005 | 11:02 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: i know this is messed up, but what do i need ? (ITR 1102)
Holy clusterfuck, you need a 45 amp fusible link where the jumper wire is. It looks like the old fusible link made contact with that top mounting bolt. If you want to reset the ecu, disconnect your bottom left and bottom right power and ground wires for 10 min. I would get rid of that brown wire and get the correct fusible link in there. That solid wire is a fire hazard.
bcumbie
Engine Management and Tuning
Mar 16, 2012 08:49 PM
monicle
Sep 20, 2005 06:19 AM
monicle
Sep 20, 2005 06:18 AM
XplodeTeg
Apr 2, 2005 09:07 PM
dingusjt
Nov 13, 2003 10:18 AM
