washer trick for chamber??
ok ive read about it before but nothing came up on search....
so my question was where does the washer go??
Modified by maRcus of EF squaD at 1:36 AM 12/20/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">On the bolts to the UCA between the UCA and the body. </TD></TR></TABLE>
does anyone have pics?? btw thanks for the info!!!
here ya go: http://home.earthlink.net/~civ....html
next time, try searching for "camber", not "chamber"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon »</TD></TR><TR><TD CLASS="quote">here ya go: http://home.earthlink.net/~civ....html
shimming the uca is a good cheap way of adding positive camber.
but getting camber straight is not good for getting maximum grip.
</TD></TR></TABLE>shimming the uca is a good cheap way of adding positive camber.
same goes for front?
</TD></TR></TABLE>same goes for front?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJxr »</TD></TR><TR><TD CLASS="quote">
same goes for front?</TD></TR></TABLE>
no, front is a whole different ball game. many more moving parts than in the rear. you have your options of adjustable upper control arms, adjustable lower balljoints, or modified spindles.
i agree with tyson, a little camber isn't so bad. helps with cornering, and like covered in other topics, incorrect toe (not camber) is what is going to wear your tires the fastest. just get yo $hit aligned when you decide on a ride height.
just get yo $hit aligned when you decide on a ride height.</TD></TR></TABLE>
Best advice ever.
Best advice ever.
CarAudioPro
10
Dec 20, 2006 02:10 PM
Built B16A
May 26, 2006 11:58 AM
Lo-Buck EF
Jul 25, 2003 04:32 PM
