my car is farting...
Ok… here’s the noise I’m getting out of my exhaust. my car is farting “puh puh”. Everything is bone stock on this car. It happens frequently when it’s cold, and than once ever other second when it’s operating temperature.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boysnightout »</TD></TR><TR><TD CLASS="quote">my guess is you might have an exhaust leak</TD></TR></TABLE>
I second that.
I second that.
Or the start of a hole somewhere.
Maybe some Bean-o might help.
Or it could be a small missfire too. since you said it happens when it reaches temperature. Yea, that sounds more likely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazy Taco »</TD></TR><TR><TD CLASS="quote">
misfire...? elaborate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck »</TD></TR><TR><TD CLASS="quote">might be a bad ignition thing or something... </TD></TR></TABLE>
my timing is good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">
instead of all the combustion happening in the engine, some of it escapes and happens in the exhaust pipe...i think..</TD></TR></TABLE>
how to check? what to check?
my timing is good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97spooncivic »</TD></TR><TR><TD CLASS="quote">by farting do you perhaps mean backfire, i dont understand your onomonapia puh puh
</TD></TR></TABLE>" it's like not an typical fart noise. like this... "pauh....puah....puah...."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej0513 »</TD></TR><TR><TD CLASS="quote">is it pretty quiet? can you hear it from inside the car?</TD></TR></TABLE>
yeah... it's louder outside than inside. my car drops in idle the same time that noise hits. i recently adjust my engine valves but i doubt this was the case because it happened before touched the valves. now it's just louder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">
yeah... it's louder outside than inside. my car drops in idle the same time that noise hits. i recently adjust my engine valves but i doubt this was the case because it happened before touched the valves. now it's just louder.</TD></TR></TABLE>
Yea thats sounds like a missfire. Not really serrious when its idling, just annoying. Some cars eventually just do that and can be hard to fix. Sometimes you just need new plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">" it's like not an typical fart noise. like this... "pauh....puah....puah...."</TD></TR></TABLE>
omg that hilarious, haha
does it smell?
does it smell?
What kind of exhaust do you have?
If you have a straight pipe this sound would be normal. No resonator or cat will cause the "puh" sound. Usually the sound will be like a puh phpuh ... lil silence... puh...
Thats what I know, if you do not have a straight pipe then I dunno.
That sounds similar to a noise that I heard after I installed my msd system. Though you may not have a msd, try some heli-core ignition wires. They are a little pricey at about $80 for the msd wires, but even if it does not fix the problem you'll be upgrading to some better equipment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Ex_Sedan »</TD></TR><TR><TD CLASS="quote">I had the same exact problem, it ran great, but starting off from a red light, or just during odd times, it'd do the same thing.
Plugs and wires, I'd recommend.</TD></TR></TABLE>
thats what i would say, my hatch did that and i cahnged my plug wires and got rid of it.
check your plug wires for corrosion or rounded spots in the rubber where it should be an edge, or cracks, etc... if they look old/worn out, they USUALLY are not good.
and take the plugs out and check em out...
That's hilarious, rofl.
asergioc
Aug 23, 2007 12:06 PM
CRISIS
15
Jan 5, 2006 07:40 AM
filipevti
Sep 9, 2005 08:17 AM
