rear disc brakes
Old Dec 19, 2005 | 09:21 AM
805ef9's Avatar
Default rear disc brakes
i gotta question for anyone.... cuz right now i have rear disc brakes off an EF-8 off a 91' si and i wanna throw it on an EF-9 hatch and i was wonderin if i would have to get brake lines off a DA or would it jus bolt right on?
Old Dec 19, 2005 | 09:58 AM
CRX Toad's Avatar
Default Re: rear disc brakes (805ef9)
Should bolt on as long as you took all the lines and everything.
Old Jan 19, 2006 | 01:13 PM
Cheeech's Avatar
Default Re: rear disc brakes (CRX Toad)
would DA ebrake cables fit on a EF?
Old Jan 19, 2006 | 01:26 PM
CRXb18Turbo's Avatar
Default Re: rear disc brakes (CheechJDM)
you have to use the 91 Si or the DA brake line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CheechJDM &raquo;</TD></TR><TR><TD CLASS="quote">would DA ebrake cables fit on a EF?</TD></TR></TABLE>
You have to use the DA/teg cables...
The CRX one is a little short... Correct me if I'm wrong.
Old Jan 19, 2006 | 01:28 PM
Mach69's Avatar
Default Re: rear disc brakes (CRXb18Turbo)
E-brake cables for an EF hatch: get 92- 93 GSR ebrake cables. (you can also probably get 90-91 gsr cables)
Old Jan 19, 2006 | 02:13 PM
Default Re: rear disc brakes (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">E-brake cables for an EF hatch: get 92- 93 GSR ebrake cables. (you can also probably get 90-91 gsr cables)</TD></TR></TABLE>
GL on finding a 90-91 GSR...
Old Jan 19, 2006 | 02:32 PM
Cheeech's Avatar
how are the gsr cables different from the LS? DA LS cables wouldnt work?
Old Jan 19, 2006 | 05:26 PM
cr-x-91's Avatar
You can use the DA's but r a lil on the long side. if u have a crx than use si, if u have hatch than use the DA. i have experience
Old Jan 19, 2006 | 06:57 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXb18Turbo &raquo;</TD></TR><TR><TD CLASS="quote">
GL on finding a 90-91 GSR... </TD></TR></TABLE>
Why were they not made?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x-91 &raquo;</TD></TR><TR><TD CLASS="quote">You can use the DA's but r a lil on the long side.</TD></TR></TABLE>
Hmm, mine fit perfectly.
EDIT: wohoo 900th post.
Old Jan 19, 2006 | 07:03 PM
GSR we intro in 93 or 92 models only..
scottso990
12
Jul 24, 2011 08:15 PM
CIVIC9922
May 18, 2011 03:17 PM
Kyle.Fitzjearl
Sep 10, 2009 05:30 AM
EJ1_Sleeper
Jun 22, 2009 09:08 PM
ThatsMyEG
Jan 17, 2005 01:31 PM
