Ques Bout Knock Sensor
My Question is what exactly does a knock sensor do b/c i have been experiencing detonation with the spark plugs at high revs and my car is throwin one code which is the knock sensor. i was told to try a full tune up which i did and i still get detonation if someone can plz enlighten me about this knock sensor an whats the best thing i can to eliminate it thanks
Its a sensor that detects ping - then retards timing. If you've been experiencing knock - the knock sensor should retard the timing to eliminate it. If its not retarding the timing - something is wrong with it.
i have an hks intake dc sport headers and hks full exhaust with Walbro fuel pump and msd spark plug wires. i believe its my ecu that might be causing it cuz its a gsr p72 non chipped and i know the fuel maps are different. I think i should have it chip an tuned. the mottor is the jdm h22 SiR-S spec or something like that
Well thats exactly yoru problem. Get a p13 or whatever that motor uses. Regardless, a p13 would work way better than the p72. Your problems will be solved. It must run like **** on the p72 - isn't that an ecu from a gsr? or civic?
well the p72 is OBD1 what if i jus chip and tune that ecu would that be fine cuz i can have the fuel maps change to the H22s cuz if i can im goin to the dyno nex w/end to chip an tune it thanks alot
thanks alot for the help i'll jus drive the car normal until i can go nex w/end and take the car to the dyno so i can chip the p72 and have the car tuned an runnin right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin »</TD></TR><TR><TD CLASS="quote">Well thats exactly yoru problem. Get a p13 or whatever that motor uses. Regardless, a p13 would work way better than the p72. Your problems will be solved. It must run like **** on the p72 - isn't that an ecu from a gsr? or civic?</TD></TR></TABLE>
to be honest it didn't run that bad but i still felt a bit of hesitation on the motor i raced my cuzins 95 5.0 stang w/ i/h/e and a racin tranny from 2nd gear rolled and still pulled him 2 cars
B18CmeFLYby
Feb 29, 2008 01:12 PM
