reccomended compression on a daily driver?
Old Dec 19, 2005 | 07:42 AM
92eg6's Avatar
Default reccomended compression on a daily driver?
i have a gsr rite now, was planning on going turbo but changed my mind being it will most likely be my daily driver for the next couple of years. so im planning on going all motor, i want to go w/cp 12.1 pistons, skunk2 valvetrain, w/sk2 stg2's, with an anr header. i would be using 93 octane and getting it tuned as soon as the motor is broken in and most likely by jeff (boosted hybrid) or by ralphy at drt being those are the best tuners i heard about on the east coast. i want the highest compression that i can get with out sacrificing reliability, is 12.1 too high or would i be able to run higher lilke 12.5, i know 13+ would be out the question but just wondering before i order my pistons, i have everything else. and are stg2's good for that compression or should i get somthing more agressive?
Old Dec 19, 2005 | 09:23 AM
Terrible One's Avatar
Default Re: reccomended compression on a daily driver? (92eg6)
with 91 octane 11.8 is the maximum i would run w/o having to retard the timing. i think 93 octane should do fine on low 12's cr. sk2 stage 2 cams are great at the cr.
Old Dec 19, 2005 | 09:52 AM
DC2 Mang's Avatar
it seems like every state in the US has 93 octane except for california, we are stuck with the 91, i have my ratio around 11.8:1 with P30 pistons and a gsr head, so you could do low 12.somethin:1
Old Dec 19, 2005 | 09:58 AM
Mohsin's Avatar
Default Re: reccomended compression on a daily driver? (JDMdc2lsVtec)
I'll be using low 12CR, since i also have access to 100RON its not too bad
Old Dec 19, 2005 | 12:04 PM
fmrprojects's Avatar
Default Re: reccomended compression on a daily driver? (Mohsin)
high 11's low 12's should be fine. I'm in cali and can only get 91 i'm running 11.7:1 compression
Old Dec 19, 2005 | 12:29 PM
92eg6's Avatar
Default Re: reccomended compression on a daily driver? (fmrprojects)
oh ok, that sux, i see som many sick rides from cali how do u guys do it w/91....here sunoco carrys 93 and 100 octane, u gotta cross the bridge to jersey but its only like a 10min drive past the bridge
Old Dec 19, 2005 | 02:49 PM
LSVTEC 91 Civic's Avatar
Banned
I'm running about 12.2-12.3:1, tuned on 93 octane with stock ignition timing (16deg)..
I drove this car from AZ to NC, and I currently have about 20k on the motor. Very streetable.
Old Dec 19, 2005 | 09:26 PM
Used2beAb16's Avatar
Default Re: (LSVT3K 91 C1V1C)
Stay around 12:1
Old Jan 10, 2006 | 12:43 PM
eg4matze's Avatar
Default Re: (Used2beAb16)
is 13.0 on 95 octane possible?
Old Jan 10, 2006 | 02:16 PM
Mohsin's Avatar
Default Re: (eg4matze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg4matze &raquo;</TD></TR><TR><TD CLASS="quote">is 13.0 on 95 octane possible?</TD></TR></TABLE>
Depends, The minimum octane we have here is 95RON which is equivalent to prem 93 in the US, but we have a range of 95-100. So your 95 Octane is 93octane equiv maybe? If so then a CR of 13 on 95 is possible but slightly on the high side.
Old Jan 11, 2006 | 01:14 AM
eg4matze's Avatar
Default Re: (Mohsin)
no I mean our 98 octan, that should be 95 octan in the us
Old Jan 11, 2006 | 07:35 AM
xEnderx's Avatar
I'm running 12.5 on 93 octane gas.....but I wouldn't really reccomend it.
Old Jan 11, 2006 | 01:38 PM
thedread's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin &raquo;</TD></TR><TR><TD CLASS="quote">
Depends, The minimum octane we have here is 95RON which is equivalent to prem 93 in the US, but we have a range of 95-100. So your 95 Octane is 93octane equiv maybe? If so then a CR of 13 on 95 is possible but slightly on the high side.</TD></TR></TABLE>
Not exactly. 95 RON is 90 to 91 in the US ((R+M)/2)
Old Jan 11, 2006 | 01:40 PM
thedread's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg4matze &raquo;</TD></TR><TR><TD CLASS="quote">no I mean our 98 octan, that should be 95 octan in the us</TD></TR></TABLE>
Your 98 RON is equivalent to 92 to 93 in the US
Old Jan 12, 2006 | 12:04 AM
eg4matze's Avatar
Default Re: (thedread)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thedread &raquo;</TD></TR><TR><TD CLASS="quote">Your 98 RON is equivalent to 92 to 93 in the US</TD></TR></TABLE>
ok thx, but I think I buy an cometic gasket and drive with 12;0 compression
Old Jan 22, 2006 | 06:56 AM
b18cvtec's Avatar
north cakalacki citgo=93 and 110 race gas at the pumps
Old Jan 22, 2006 | 12:37 PM
Mohsin's Avatar
afaik our 95RON is your prem 93 RON.
Old Jan 22, 2006 | 01:18 PM
kc4door's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">it seems like every state in the US has 93 octane except for california, we are stuck with the 91, i have my ratio around 11.8:1 with P30 pistons and a gsr head, so you could do low 12.somethin:1 </TD></TR></TABLE>
we only get 92octane at the BP stations in kansas city
Old Mar 8, 2006 | 02:40 PM
EF9_R_Killa's Avatar
what are you guys doing for fuel management to compensate for the high compression but with our low octaine here in cali?
Old Mar 8, 2006 | 07:40 PM
redhondacivic's Avatar
Default Re: (EF9_R_Killa)
According to the compression calculator I am running 12.26:1 I live in Oregon, running 93 octane tuned on Hondata s100 (Too Rich I Think). 15k on motor.
Old Mar 8, 2006 | 08:21 PM
xiaogou's Avatar
IMO 12.5 should be the max.
Old Mar 9, 2006 | 06:23 AM
Dan Ruddock's Avatar
Default Re: (xiaogou)
Anything over 11.0 will give you very little detonation head room and you could get small amounts of inaudible detonation that will shorten the life of your motor. If getting the maximun life from your motor is not important to you run more. Dan
Old Mar 11, 2006 | 02:39 AM
eg4matze's Avatar
Default Re: (Dan Ruddock)
and what is with oem turbo engines? They have an effective compression till 15:1
Old Mar 11, 2006 | 07:50 AM
NAlover's Avatar
Default Re: (xEnderx)
why not???
Sully90SiPrelude
Nov 28, 2006 10:42 AM
spooncivic1
Dec 20, 2004 06:44 PM
donnjuan2point2
Jun 25, 2003 03:22 PM
Rocket
May 5, 2002 12:32 PM
Chuji
Oct 30, 2001 07:26 PM
