h22 no rev past 6200rpm, why?
i have an h22 in an 92 accord...check engine light code: knock sensor...and i changed it twice...and i still get check eng light, even after reseting the ecu...what cause the motor not to rev past 6200rpm???? I'm about to junk this ****....get me a bike
Modified by acclude-vtec at 9:27 AM 12/19/2005
Which ecu are you using?
Did you do the swap and wiring yourself? Or a previous owner? A shop?
When did the problem start? Any other symptoms?
It somewhat sounds like you're running the wrong ecu.
I have to agree, It sounds like you're up against a rev limiter.
Procure different ECM
Chip your ECM
Install a different EMU
etc etc etc
P
Chip your ECM
etc etc etc
P
