Poly bushings on back but not front
Old Dec 19, 2005 | 06:21 AM
Psionic's Avatar
Default Poly bushings on back but not front
I'm in the process of doing an integra brake conversion on my CRX. When I pulled off my trailing arms, I killed a few of the bushings in the process. So now I have to buy new bushings. Ideally I would like rubber bushings, but they are like $60 a piece b/c you have to buy them from Honda (am I wrong?). So I could go with poly bushings, but then I would only have them on the back. Is that going to cause problems having them on the back and not the front?
I don't really want any poly bushings, b/c ride quality is important, but I also don't want to spend hundreds of dollars on a few pieces of rubber...
Old Dec 19, 2005 | 06:35 AM
Targa250R's Avatar
be professional
Default Re: Poly bushings on back but not front (Psionic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Psionic &raquo;</TD></TR><TR><TD CLASS="quote">am I wrong?</TD></TR></TABLE>
Yes. Most of the rear suspension bushings are $15 (USD) each or less. None are more than $24, except for the big trailing arm bushings, which are $43-46 apiece.
For the small bushings:
http://www.slhondaparts.com/br...R+ARM
For the TA bushings, read here:
http://www.performanceforum.co....html
To answer your other question - no, it won't cause any harm to have poly bushings in just the rear.
Old Dec 19, 2005 | 07:52 AM
CRXB16T's Avatar
Default Re: Poly bushings on back but not front (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">For the TA bushings, read here:
http://www.performanceforum.co....html</TD></TR></TABLE>
Very informative site. Thanks!
Old Dec 19, 2005 | 09:39 AM
Psionic's Avatar
I know it won't cause any HARM to have non-poly on the front - but if you stiffen the back and not the front it will be more prone to understeer, no? Or is it super-miniscule?
Good site by the way.
Old Dec 19, 2005 | 09:56 AM
CRX Toad's Avatar
Default Re: (Psionic)
Problem is that the trailing arm bushings in urethane cause the suspension to bind because if doesn't allow that bushing to move properly as the factory intended. So in the cause it isn't a problem of over/understeer.
Old Dec 19, 2005 | 10:39 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Psionic &raquo;</TD></TR><TR><TD CLASS="quote">I know it won't cause any HARM to have non-poly on the front - but if you stiffen the back and not the front it will be more prone to understeer, no? Or is it super-miniscule?
Good site by the way.</TD></TR></TABLE>
you really shouldnt be concerning yourself over the effects of poly in a front/rear handling change kind of perspective. its just not that significant or directly related.
and busting a bushing or two shouldnt be your reason for switching to poly.
you can get really cheap replacement bushings from here. at least they show em available. its not OEM, but i imagine some of their brands are OEM suppliers.
http://www.importpartsspec.com/
however, i still recommend getting straight from OEM if you have the budget.
emr88
Feb 20, 2011 05:29 PM
marcsed6
11
Dec 27, 2009 07:02 PM
dbailey
11
Jan 15, 2007 06:41 PM
OMG WTF
Suspension & Brakes
Jul 20, 2006 07:49 PM
viper1984
21
Feb 28, 2006 06:21 AM
