removing crank pulley
Old Dec 19, 2005 | 03:57 AM
f150harleytruck7's Avatar
Default removing crank pulley
how do u remove the crank pulley on a 1.6 civic, and is it regular or reverse thread?
Old Dec 19, 2005 | 04:09 AM
jadugartir's Avatar
Default Re: removing crank pulley (f150harleytruck7)
have to get a damn special tool unless you have one hell of an impact.
It fits inside the hex shaped hole in the crank and lets u put a breaker bar on there and one on the bolt and you can crack it loose. they cost like 25 bucks on amazon.com.
Old Dec 19, 2005 | 05:37 AM
96 EX's Avatar
Default Re: removing crank pulley (jadugartir)
jesus christ dude we spent 3 hours trying to get the crank pulley and the harmonic balancer off of mine and broke 4 nuts and finally on with a heavy duty impact wrench(200pounds) got it off..
Old Dec 19, 2005 | 05:40 AM
Default Re: removing crank pulley (96 EX)
it tried a large impact but it did nothin, maybe need more psi , the compressor only goes to like 100psi, did u use somethin to support the pully?
Old Dec 19, 2005 | 06:37 AM
O RLY's Avatar
We got a breaker bar and literally stood on the bar. Theres a chance of breaking something, but I've used this technique three times and it has yet to fail me.
Old Dec 19, 2005 | 06:42 AM
chinkest_raver's Avatar
lol i have tried for 6 mos now and still i can't good luck. I tried standing on it with a breaker bar everything. i might just take it in to a shop and get it off..i need to rebuild my motor!
Old Dec 19, 2005 | 07:08 AM
littleredcivic's Avatar
the honda crank pulley removal tool is the ****. if someone needs them, call your snap on guy or head to the honda dealer. if you are in the so cal, you can borrow mine for a burger and some fries.
Old Dec 19, 2005 | 07:10 AM
Default Re: (littleredcivic)
i ahve 2 motors, one has the hex for that tool, but the other one has hols aroud the outside edge, how would i get that one off?
Old Dec 20, 2005 | 07:36 AM
can i see pictures of the one with holes? what year is that from? what model?
Old Dec 20, 2005 | 07:40 AM
suprmods's Avatar
the holes are probably from when they balanced the pulley. They drilled the holes to remove the weight at that area.
Here is a recent thread discussing the same thing.
https://honda-tech.com/zerothread?id=1461254
A chain wrench works well at holding the pulley, otherwise you could try jamming a screwdriver in the flywheel (I didnt try it but others say it works).
Old Dec 20, 2005 | 08:09 AM
kleanlscivic's Avatar
i used an impact gun, no problem at all but get the honda special tool
EgSalad
22
Oct 7, 2005 05:03 PM
Draggin99Si
59
Feb 20, 2005 11:59 AM
.cingham
39
Apr 11, 2004 12:05 AM
yuckymucky
21
Mar 30, 2003 07:04 PM
Lei Siew Long
Sep 11, 2001 11:39 AM
