Timing Belt ITR OEM, GREDDY, or TODA
Old Dec 18, 2005 | 10:24 PM
BlUeHoOdCiViC99's Avatar
Default Timing Belt ITR OEM, GREDDY, or TODA
when using Skunk 2 stage 2 pro series cams can you do alway with just an ITR OEM timing belt need feedback from people that are doing 200whp to the wheels with after market cams WHAT TIMING BELT are you guys using etc
Old Dec 19, 2005 | 12:04 AM
fmrprojects's Avatar
Default Re: Timing Belt ITR OEM, GREDDY, or TODA (BlUeHoOdCiViC99)
im putting down 217whp and im using an oem gsr timing belt from the dealer. 11k milkes on it no problems still looks good
Old Dec 19, 2005 | 12:21 AM
Pandahatch's Avatar
I had a Greddy one, but for some reason it has tight spots in it, I switched to an OEM one and it's perfect...this is in a car that revs to 10k and USED to have Pro 1 cams, Pro 3's are going in now.
Old Dec 19, 2005 | 09:32 AM
Default Re: (PandaHatch)
thanks for all the feed back guys reason why i was asking was because i read an article that Michale D wrote on toda cams and the need of a toda belt to have the system running good
Old Dec 19, 2005 | 09:41 AM
Black R's Avatar
25 Year Member
I used Power Enterprise for 25k miles with no problems whatsoever and toda b/ toda c cams.
I have since changed to toda belt and am still using toda c cams. No problems whatsoever, and it even took a couple of 12k rpm zings like a champ without any damage whatsoever...
Old Dec 19, 2005 | 09:58 AM
DC2 Mang's Avatar
Im using an OEM one, and everyone i know has used one too (ITR, GSR, B20vtec, LSvtec motors) and never had a problem
Old Dec 19, 2005 | 01:58 PM
The Tea-father's Avatar
Default Re: Timing Belt ITR OEM, GREDDY, or TODA (JDMdc2lsVtec)
I used both toda and greddy, both of the work great!
Old Dec 19, 2005 | 02:55 PM
SkRiBLaH's Avatar
Default Re: Timing Belt ITR OEM, GREDDY, or TODA (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">I used Power Enterprise for 25k miles with no problems whatsoever and toda b/ toda c cams.
I have since changed to toda belt and am still using toda c cams. No problems whatsoever, and it even took a couple of 12k rpm zings like a champ without any damage whatsoever... </TD></TR></TABLE>
why may i ask did your motor zing to 12?
Old Dec 19, 2005 | 05:53 PM
scUba-stEve's Avatar
Default Re: Timing Belt ITR OEM, GREDDY, or TODA (SkRiBLaH)
probably mis shift...
Old Dec 19, 2005 | 06:16 PM
Default Re: Timing Belt ITR OEM, GREDDY, or TODA (zer0-psi)
MAYBE
Old Dec 19, 2005 | 06:33 PM
Drag_Racer_DRU's Avatar
Toda belt is Red if you like that color or are a member of the bloods street gang
Old Dec 19, 2005 | 06:58 PM
rodimus's Avatar
Default Re: Timing Belt ITR OEM, GREDDY, or TODA (Drag_Racer_DRU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_Racer_DRU &raquo;</TD></TR><TR><TD CLASS="quote">Toda belt is Red if you like that color or are a member of the bloods street gang </TD></TR></TABLE>
then you can also rock a cincinatti reds cap to match lol.
Old Dec 19, 2005 | 07:20 PM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zer0-psi &raquo;</TD></TR><TR><TD CLASS="quote">probably mis shift...</TD></TR></TABLE>
yup, a couple of good times from 4-3 at 9k rpm...!
Old Dec 19, 2005 | 08:42 PM
last time i did that i bent some valves was not very happy
Old Dec 19, 2005 | 10:25 PM
t's Avatar
t
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">Im using an OEM one, and everyone i know has used one too (ITR, GSR, B20vtec, LSvtec motors) and never had a problem </TD></TR></TABLE>
Yep everyone I know use OEM belt, even 700+ turbo motor is using oem belt.
Old Dec 19, 2005 | 11:34 PM
rjay8604's Avatar
Default Re: Timing Belt ITR OEM, GREDDY, or TODA (t)
OEM timing belts are the shiz. I've heard more bad stories about performance T-belts than i have with OEM. OEM for the win!
Old Dec 20, 2005 | 12:11 AM
totsie7944's Avatar
Default Re: Timing Belt ITR OEM, GREDDY, or TODA (rjay8604)
I have OEM on Toda Spec C's. Been good to me....
HondaIntegraR
Mar 25, 2005 12:51 PM
43MA
Dec 16, 2004 11:56 PM
chet
Feb 8, 2004 02:47 PM
cvclover
13
Nov 3, 2003 11:37 AM
DA MUGEN 1
Mar 29, 2003 07:14 AM
