IF THIS WAS YOUR CAR...
Old Mar 17, 2002 | 05:57 AM
vtec-outlaw's Avatar
Default IF THIS WAS YOUR CAR...
Would you put a Zex nitrous system (55 shot) on your GSR. 80,000 miles 255 lph fuel pump, ZEX plugs, intake, exhaust.
Would you do it if it was yours??????
Old Mar 17, 2002 | 08:07 AM
yellowbuffalo's Avatar
Default Re: IF THIS WAS YOUR CAR... (vtec-outlaw)
go NA 80,000 to much miles for nitrous
Old Mar 17, 2002 | 09:03 AM
Frito1's Avatar
Default Re: IF THIS WAS YOUR CAR... (slipknot23)
rebuild the motor and port and polish that son of a bitc#. after that you can do anything you want.
1998 gsr
ITR catback
JDM ITR header
JDM ITR oem intake
and lots more JDM goodies.
ground control coilovers
Honda badges
[Modified by tegsleeper, 6:05 PM 3/17/2002]
[Modified by tegsleeper, 6:06 PM 3/17/2002]
Old Mar 17, 2002 | 10:23 AM
Jesse H's Avatar
Alot of folks will agree that a Honda motor with 100K miles on it is just broken in. But if anybody wants to boost one that isn't relatively new you suggest it's a bad idea without anything backing it up.
It's ok to boost an old motor. Find out what shape it's in. Does it burn oil? What kind of gas mileage are you getting? How's the compression, how about a leak-down test? Has it been properly maintained it's entire life?
There are lots of CRX-ers that boost their D16's and ZC's, and those aren't new motors. There's a difference between old, and tired and old.
Old Mar 17, 2002 | 12:59 PM
Etylorcen's Avatar
Default Re: (Jesse H)
Always do a compression and leakdown test before doing anything major.
Old Mar 17, 2002 | 03:30 PM
KooK's Avatar
Mustang Sally
Default Re: (Etylorcen)
How do you do a leakdown test and how much does it cost to get something to do a compression test? Thanks!
Old Mar 18, 2002 | 03:44 AM
SoCal ITR's Avatar
Default Re: (Gozzy)
I don't think I'll ever use nitrous.
Old Mar 18, 2002 | 03:48 AM
MiraiZ's Avatar
Default Re: (SoCal ITR)
Naaaaaws!....BOOOM!...there was some truth to the movie
Old Mar 18, 2002 | 11:51 AM
Slopoke's Avatar
Default Re: (MiraiZ)
My LS motor has almost 80,000 miles on it. Ive been racing it since 40,000 and Ive been running a 70 shot on it for the last 5-8 thousand miles. Im about to ditch my dry kit for a direct port and up it to 100 shot(all internals are stock). I am confident that my motor (which still runs perfect) will still last a very long time.
Take it to a dealership or shop and have them do a leak down and compression test. If everything is in good shape, go for it. A 55 shot is nothing, your gsr motor will take it w/ out breaking a sweat. Just make sure your kit is installed properly, running correctly, and use it responsibly and you will be very happy w/ it.
Dont listen to the uninformed people who assume that you car will blow up as soon as you use nitrous. Do some research and learn for yourself.
Good luck.
sohc_powered
23
Jul 28, 2007 04:08 PM
digital sol
May 31, 2005 01:54 PM
Viper8L488
11
May 19, 2005 11:29 AM
I Like Boost
Apr 29, 2003 10:23 AM
2fastGSR
Jun 26, 2001 09:10 PM
