FS: built D16Y8, D-series turbo kit, B-series blockguard, 4G civic exhaust
B16/B17/B18 Golden Eagle blockguard $85
brand new, never used, I was shipped the wrong item
88-91 Civic/CRX 3" exhaust/test pipe. Bolt on. Full 3" mandrel bent, stainless canister style muffler, 5.5" tip with silencer.
D16Y8 new all honda seals, water pump, and thermostat, eagle rods, srp 9.0:1 pistons, golden eagle blockguard, ARP head studs, bored .25mm over, zero miles, incl. intake manifold, 7.5lb aluminum flywheel, and a used Clutch Specialties 6-puck unsprung clutch. make offer.
D-series cable trans, OBX limited slip differential, $500
Turbo kit for 88-91 civic, OBX equal length manifold, Nissan T3 (supports about 300whp, can be modified for over 400whp), 35mm external wastegate, SSQV style BOV, full 2.5" mandrel bent charge piping, silicon couplings & clamps, goodridge oil feed line w/T block, stainless/teflon return line w/ fittings, 3" x 6" x 30" front mount intercooler (includes clearanced front bumper and mounts), ECU with base tune, pillar pod with boost and air:fuel gauges. Make offer.
Has this motor ever been ran or just built and never put in?? I'd be willing to meet halfway depending on the price. I need a y8 and a built one is even better for me. saves some time
