Trans fluid question
Old Dec 18, 2005 | 08:29 PM
E.Honda's Avatar
Default Trans fluid question
What should be used in the gsr 5 speed as far as fluid?
2.5 qts?
I looked at autozone and saw nothing and they did not know what to sell me.
Thank you
E.Honda
Old Dec 18, 2005 | 08:55 PM
jdm123's Avatar
Default Re: Trans fluid question (E.Honda)
honda manuel transmission fluid
Old Dec 18, 2005 | 09:02 PM
jadugartir's Avatar
Default Re: Trans fluid question (jdm123)
in the autozone computers it says "10w-30 or 10w-40" but i suggest mobil 1 10w-30.
Old Dec 18, 2005 | 09:47 PM
E.Honda's Avatar
Default Re: Trans fluid question (jadugartir)
10w 30 motor oil?
Reg or synthetic?
Old Dec 18, 2005 | 11:47 PM
EJ8VTEC's Avatar
Mr. Indecisive
synchromesh, like 1.5qt will be enough
Old Dec 19, 2005 | 12:53 AM
E.Honda's Avatar
Default Re: Trans fluid question (EJ8VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC &raquo;</TD></TR><TR><TD CLASS="quote">synchromesh, like 1.5qt will be enough</TD></TR></TABLE>
I saw nothing that said synchromesh at the local parts shops.
Old Dec 19, 2005 | 06:26 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda &raquo;</TD></TR><TR><TD CLASS="quote">
I saw nothing that said synchromesh at the local parts shops.</TD></TR></TABLE>
Try any GM dealer's parts counter. Also, i think its 1.8 qts for a b tranny.
Old Dec 19, 2005 | 06:30 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Trans fluid question (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC &raquo;</TD></TR><TR><TD CLASS="quote"> like 1.5qt will be enough</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote"> Also, i think its 1.8 qts for a b tranny. </TD></TR></TABLE>
neither one of you guys must have completely drained the trans, or you were not on a level surface. you should buy 3 quarts, and if properly drained and level, it will take 2.4 quarts or so.
oh, and my take is to run regular honda mtf. nothing wrong with it at all.
Old Dec 19, 2005 | 06:32 AM
IHateJDM's Avatar
Default Re: Trans fluid question (Rodney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney &raquo;</TD></TR><TR><TD CLASS="quote">
I don't even own a B, but my H took 2.1 qts to fill after my swap. Never knew a B tranny held more fluid.
Old Dec 19, 2005 | 08:07 AM
EJ8VTEC's Avatar
Mr. Indecisive
oh, and my take is to run regular honda mtf. nothing wrong with it at all. </TD></TR></TABLE>
No i wasnt on a level surface, i jacked the drivers side up to drain it, then i jacked the passenger side up to fill it, so i could get more in... i bought 2 n didnt get the 2nd one all the way in... so maybe more like 1.7.. The manuel said 2.3 i think, but i couldnt get that much in even w/ one side jacked up
Autozone carries it
Old Dec 19, 2005 | 08:27 AM
dohcVTECeg2's Avatar
your tranny should take no more then 2.5 use HG. honda genuine MTF. or syncromesh
Old Dec 19, 2005 | 10:04 AM
NJcoupe's Avatar
Personally, People have told me not to do it, But I use 1 quart of Penzoil Synchomesh, and the Remaining 2.2 Quarts of Mobil 0-40. I've never had ANY problems and shifts very smoothly.
Old Dec 19, 2005 | 10:07 AM
boostedcivicsir's Avatar
Mr. Badwrench
yup. i usually pour all 3 qts in the vss hole and then pop out the fill plug to let the excess out. because i am too cheap to go get a plews suction gun. but 2.4-2.8 qts should be the correct number.
and i always use honda MTF.
Old Dec 19, 2005 | 03:43 PM
Rodney's Avatar
Default Re: Trans fluid question (boostedcivicsir)
i just double checked in the helms, looks like it is 2.4 quarts for overhaul, 2.3 for fluid change.
Old Dec 19, 2005 | 04:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney &raquo;</TD></TR><TR><TD CLASS="quote">i just double checked in the helms, looks like it is 2.4 quarts for overhaul, 2.3 for fluid change. </TD></TR></TABLE>
nholmes
Aug 9, 2006 01:46 PM
4drITR
Jun 1, 2006 03:40 PM
mmmsushi
Oct 23, 2005 09:37 AM
Cyphear
Jun 20, 2004 03:51 PM
5spdIntegra
Mar 29, 2004 08:52 PM
