How should I replace this piece?
Old Dec 18, 2005 | 06:15 PM
rasinhell's Avatar
Default How should I replace this piece?
hey guys, i bought a brand new skunk 2 intake manifold off my friend for 100 bux. the only thing wrong with it is the tube on the back has been pinched somehow, possibly from dropping it..
the tube im talking about is the one that is the very top most in this picture. I think its for vacuum. Anyways, how should these be replaced? I have one off of my old intake mani that should fit.
So whats the "proper" way to remove and replace it?
UPDATE---
Okay here are pictures
Modified by plugg'd at 8:10 PM 12/18/2005
Old Dec 18, 2005 | 06:16 PM
dohcVTECeg2's Avatar
Default Re: How should I replace this piece? (plugg'd)
hmmm i would like to know as well
Old Dec 18, 2005 | 06:45 PM
astroxtc's Avatar
Default Re: How should I replace this piece? (dohcVTECeg2)
id just cut it off and fab and weld another one
Old Dec 18, 2005 | 07:11 PM
rasinhell's Avatar
Default Re: How should I replace this piece? (astroxtc)
that doesn't sound like the most efficient idea. there has to be a better way right?
Old Dec 18, 2005 | 07:14 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
u can try heating it with a blow torch and try to shape it back to where its supposed to be. Try the welding/fabrication forum, they may have a solution
Old Dec 18, 2005 | 07:16 PM
G2 Speed's Avatar
Default Re: How should I replace this piece? (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">u can try heating it with a blow torch and try to shape it back to where its supposed to be. Try the welding/fabrication forum, they may have a solution</TD></TR></TABLE>
it would bend back yes... but there would still be a dent in the middle.... I think it would be best just to weld a new one....
Old Dec 18, 2005 | 07:18 PM
LSEGHATCH's Avatar
Is it threaded?
Old Dec 18, 2005 | 07:20 PM
G2 Speed's Avatar
Default Re: How should I replace this piece? (LSEGHATCH)
I couldn't see it being threaded
Old Dec 18, 2005 | 07:21 PM
rasinhell's Avatar
okay guys. i tried "unthreading" it, and it just bent the tube... so i dont think its threaded... anyway i tried unbending it, but it still left a slight bottleneck...
here is a picture
do you think that it's okay having a bottleneck like that? I mean, would it have any negative effects? i can blow air through it easily..
Old Dec 18, 2005 | 07:22 PM
MikeD718's Avatar
Default Re: How should I replace this piece? (G2 Speed)
i would heat it up and stick a screw driver or something in the hole and try to pry it back.
Old Dec 18, 2005 | 07:32 PM
rasinhell's Avatar
hrm, so u think its not good enough the way i bent it?
Old Dec 18, 2005 | 07:36 PM
hatchi's Avatar
the way its bent back is good enough for it
Old Dec 18, 2005 | 07:37 PM
MikeD718's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">the way its bent back is good enough for it</TD></TR></TABLE>
you beat me to my post i think it would be fine i have had to do things like that before and it worked out fine.
Old Dec 18, 2005 | 07:46 PM
rasinhell's Avatar
Default Re: How should I replace this piece? (MikeD718)
cool, thanks guys. there is some mystery dude that sent me IMs, thanks.
Old Dec 18, 2005 | 07:58 PM
RTI's Avatar
RTI
That is only to apply vacuum to the brake booster, right? I can't see there being a whole lot of airflow in that fitting.
Old Dec 18, 2005 | 09:03 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: How should I replace this piece? (RTI)
so long as theres no hole in the tube part in the inside of the elbow, thats enough vacuum for the brakes, the booster doesnt need a wide tube to draw air, its not doin a vacuuming constantly. It will be alright.
Old Dec 18, 2005 | 11:55 PM
built562's Avatar
Default Re: How should I replace this piece? (Redline96LX)
it should be fine the way it is.
but if you want to replace it you will need to get it out, take some vice grips and clamp it on and work it back and forth to get it out.
then get some generic brake hard line tubing slightly larger in OD than the stock tube you are removing, cut it to approximate size and lightly tap it in the hole with a hammer, then you will be there with a straight tube out of the manifold, then get a small tubing bender and viola!, then put a small hose clamp on the booster hose
Old Dec 19, 2005 | 01:41 AM
E.Honda's Avatar
Default Re: How should I replace this piece? (built562)
Cut it off before the kink and use a hose clamp to hold on the hose.
Pretty simple fix.
Modified by E.Honda at 10:43 AM 12/19/2005
Old Dec 19, 2005 | 08:58 PM
xSIx's Avatar
buy a new one???
Old Dec 19, 2005 | 09:05 PM
SiR:Mallard's Avatar
Why can't you just snap it off and use a tap to thread a new hole? Dump a AN fitting in there and call it a day.
Old Dec 19, 2005 | 09:50 PM
PurEvl's Avatar
dude that **** is fine.
Old Dec 20, 2005 | 02:37 AM
94hatchling's Avatar
Default Re: How should I replace this piece? (E.Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda &raquo;</TD></TR><TR><TD CLASS="quote">Cut it off before the kink and use a hose clamp to hold on the hose.
Pretty simple fix.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR:Mallard &raquo;</TD></TR><TR><TD CLASS="quote">Why can't you just snap it off and use a tap to thread a new hole? Dump a AN fitting in there and call it a day.</TD></TR></TABLE>
i would go with one of these two. thats what i thought of.
Old Dec 20, 2005 | 03:43 AM
hondasport2000's Avatar
Pretty simple fix.
Modified by E.Honda at 10:43 AM 12/19/2005</TD></TR></TABLE>
my suggestion as well.
Old Dec 20, 2005 | 07:55 AM
PurEvl's Avatar
why make it harder than what it is??
that **** aint that fucked up enough to waste this much time to expletive with.
Old Dec 20, 2005 | 08:00 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (PurEvl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PurEvl &raquo;</TD></TR><TR><TD CLASS="quote">dude that **** is fine.</TD></TR></TABLE>
