LsVtec Rev Limit???
hey my buddy just bought a 92 hatch with a b18b block and gsr head, it has JE pistons and 11.4:1 compresion ratio and i was wonderin what this thig will rev to without blowing the engine??? please help asap!!!
-thanks
-thanks
Were oil squirters installed? (or do they come standard on the LS I'm not sure)
I don't see why you couldn't rev to 8000. It's only 800 higher than normal, and usually the rev-limits are determined by the valvetrain setup. I would say the top end can take 8000 no problem, maybe ask the builder of the engine or retailer of JE pistons what they think just to be sure.
B
B
depending on what rods and if they have stronger rod bolts.. if it doesnt then i would 8k wouldnt be a problem at all.. i rev mine up to 8500 all day everyday for the past 11K miles.. havent had a problem yet.. i have stock rods with arp bolts.. and a gsr girdle installed.. hope that helps a lil..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93slmdcvcsi »</TD></TR><TR><TD CLASS="quote">I hav type r pistons, ls rods and arp rod bolts, b16 head with type r cams and i take mine to 8900 all day for the past 20,000 miles</TD></TR></TABLE>
off topic, but how much power did you make with those type r pistons... im in the middle of buying some and i couldnt decide between those and cp...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90efSI »</TD></TR><TR><TD CLASS="quote">hey my buddy just bought a 92 hatch with a b18b block and gsr head, it has JE pistons and 11.4:1 compresion ratio and i was wonderin what this thig will rev to without blowing the engine??? please help asap!!!
-thanks</TD></TR></TABLE>
id say to stay on the safe side and dont go past 8k until you get it checked out by a speed shop.
hondapowaa
13
Nov 4, 2007 05:26 AM
hondapowaa
Nov 2, 2007 01:23 PM
