02 sensor question
lol
the male plug of the o2 sensor should only plug into one female plug from the harness.
did u get a stock header from a d16y8, or aftermarket? if aftermarket which motor did u get it for? a d15b, d16z6, or d16y8?
if it's for a d16y8 I think you will have 2 spots for 2 o2 sensors. you only need to use one if u have a 94 hatch. pick the one closest to the o2 male plug, its the plug nearest to the radiator if your car was orignally a CX, VX, DX, but if it was Si, EX then it will be under the intake manifold somewhere.
However if it was originally a CX or VX and you are still using your original engine harness you will have to convert the o2 sensor male plug wires to a 4wire o2 system. you can do a search on topics I have posted in and you will find the info/link.
if you're using the original engine harness you dont have to convert to 4wire it will already be 4wire o2 system that came with the d16y8, I believe you have 2 choices as to where to put the o2 sensors. choose whatever fits. there will be one near the distributor/transmission area and one under the intake manifold somewhere.
