rpm raises fast then drops fast sometimes in idle
rpm raises fast then drops fast sometimes in idle any suggestions on what the problem could be? when i drive around 10-15mph the rpm just rise and fall real quick and i have to pull up on the gas pedel to calm it down it is wierd. should i ajust the linkage on it or what? thanx
It would help If i knew what you were driving.
Some things that it could be:
throttle linkage
alternator
fuel pump
fuel injectors (if equipped)
carbuerator (if equipped)
Those are some ideas, I could narrow it down more if I knew what engine you're dealing with.
throttle linkage
alternator
fuel pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oluva »</TD></TR><TR><TD CLASS="quote">rpm raises fast then drops fast sometimes in idle any suggestions on what the problem could be? when i drive around 10-15mph the rpm just rise and fall real quick and i have to pull up on the gas pedel to calm it down it is wierd. should i ajust the linkage on it or what? thanx</TD></TR></TABLE>
different cars require different diagnostic methods ..........start by telling us year and model.........but it sounds like a fast idle valve leaking by , idle too high, vacc leak..
