dash lights problem 96 coupe
Old Dec 18, 2005 | 12:02 PM
7808's Avatar
Default dash lights problem 96 coupe
sometimes when i turn my headlights on, my dash lights dont come on, then a smack the top of my dash and they come on, or flicker and come on, few times the oem radio backlit came on a few sec after the dash lights...
anyone else delt with this before? where should i start?
Old Dec 18, 2005 | 12:17 PM
ekcivic9's Avatar
i have the same problem... except its just my climate control.
my fuses are fine, but maybe you can check yours.
bump for answers!
Old Dec 18, 2005 | 01:43 PM
MaRkO's Avatar
Default Re: dash lights problem 96 coupe (7808)
Are you equipped with a dimmer switch? If so that's the likely culprit. After time, the wires come loose on the switch. Next time try and whacking the switch instead of the whole dash. Hope that helps.
Old Dec 18, 2005 | 03:42 PM
JDM-EJ1's Avatar
Default Re: dash lights problem 96 coupe (MaRkO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaRkO &raquo;</TD></TR><TR><TD CLASS="quote">Are you equipped with a dimmer switch? If so that's the likely culprit. After time, the wires come loose on the switch. Next time try and whacking the switch instead of the whole dash. Hope that helps.</TD></TR></TABLE>
Exactly what I was thinking.
Old Dec 18, 2005 | 06:50 PM
7808's Avatar
Default Re: dash lights problem 96 coupe (JDM-EJ1)
you guys are good. before i even read that i started thinking and i was like damn i bet its my dimmer switch, sure enough when i tap on it **** happens.. thanks
vartok
May 20, 2014 04:28 AM
Luchini
Dec 19, 2008 09:47 PM
italianchooch88
Feb 13, 2008 01:45 PM
96blackgsrfst
Oct 10, 2007 05:15 AM
Timmay
38
Mar 17, 2006 01:26 AM
