Stock Integra Type R Spring Length
Hey guys, I got a 92 Civic w/ Koni Yellows and Type R springs. I need to upgrade the spring rates for track use. I love the ride height, and I don't really want to spring for coilovers, so I'd like to get just springs at the same length as these ITRs. So I guess I should just get to the question:
Do you guy's know the spring length of the stock type R springs?
if oyu buy a spring the same length with higher spring rates your ride height will be raised because the spring wont compress as much as a softer rated spring would. think about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4 »</TD></TR><TR><TD CLASS="quote">if oyu buy a spring the same length with higher spring rates your ride height will be raised because the spring wont compress as much as a softer rated spring would. think about it.</TD></TR></TABLE>
Thanks! Now how long is the damn stock spring length? Come'on I know you guys know this factoid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooch’n »</TD></TR><TR><TD CLASS="quote">search....saw a great post with a picture of all the stock LS/GSR springs and shocks vs ITR and specs
I did, a hundred different ways and found nothing. If you know, just let me know...
</TD></TR></TABLE>I did, a hundred different ways and found nothing. If you know, just let me know...
pjr710
Suspension & Brakes
19
Apr 19, 2007 02:44 PM
Superhatch
10
Feb 8, 2002 06:59 PM
