How much to fix body damage??
that is a pretty easy fix, all you'd have to do is take your sideskirt off, bend the metal back, clean it up, primer it and shoot some paint on it.
Or if you wanted to be lazy you could just bondo that gap, primer and paint.
I'd say 200-400 bucks to fix
That area is difficult to access from the inside because the seatbelt mounts there. I'd say $1500 to have it done correctly by a body shop.
It looks like you dropped the rocker on something. How did you do this?
From experience from a similar problem, expect $500 to $700. Someone said earlier that its not an easy fix, and they are right. It looks like an easy fix, but the metal there is light and flimsy, plus the bend is on a curved piece of metal and matching the curve will be hard. A bad shop will pull it and hammer it out, or bondo it, and it will probably break if its bent back out, or will be wavy and wont look right. A good shop will pull it out and add metal wherever the bends dont look right or cut it out completely and replace it with new metal, then paint it and color match it. Expect it out at least a week also, which will be the most of your costs. Good luck, dont get ripped off, go to a reputable place
From my experiences, im guessing about 900 because like others said, it is a difficult spot to work with, and their going to probably paint that whole back panel from the front of the door to the rear bumper and then fade it to match the rest of the car. It very time consuming and at a rate of 50 bucks an hour...lots of money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg »</TD></TR><TR><TD CLASS="quote">Replace front fendor and paint match, $300-$600.</TD></TR></TABLE>
its not the front, its the rear quarter.
lol and yeah id have to say its gunna be like 700+ cause if you go to a good shop thats a costly little job with the location and all.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy »</TD></TR><TR><TD CLASS="quote">for a shop to do it 1500-2000. but if you got a hook up shop like me then 500-900
edit: thats the quarter panel right? if so then yea its gonna cost $$$</TD></TR></TABLE>
LMAO
LMAO
had a simlar accident(fire hydrant, tore up alot more). had to get the entire rear qaurter replaced, cost me about 1700.
like said, that is not a simple bend back job. get it done correctly.
that ***** nothing. i work at a body shop on long island an we would charge 4-500 max to pull it and paint it....if u drive it here i'd do it for u for 300$ i cant believe ppl are sayin 1500 for that...there outta their minds... im around this **** all day ......thats a 3-4 hour job its nothing.
hmm. try to fix it urself as best u can and see how it comes out. cas u wont make it any worse. then get it painted , or hav it professionaly all done for almost a "G"
all of you have no idea what yrou talking about, that will buff right out!
haha but seriously i'd just hammer it alil and get type R sides to cover it up.
t0p_sh0tta
Paint and Body
May 29, 2007 06:16 AM
Big Ed
Jan 15, 2002 10:34 PM
