Warped Turbo Flange - Will It Leak? .015 Gap - Any HighTemp Sealants?
Old Dec 18, 2005 | 12:35 AM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Warped Turbo Flange - Will It Leak? .015 Gap - Any HighTemp Sealants?
I noticed after bolting my manifold and turbo together that Ive got a small gap. I can slide a metal scale in there and that measures .016 on the vernier, real tight in some spots but I can get it through
Now I know a lot of **** obviously isnt always true but is .015-.020 thou to much and will just leak like a mother ******?
Its to cold for me to want to take it apart and get it remilled plus Id be weary of my turbo being milled
Do you guys think it will leak? Will exhaust carbon plug it up right away?
Anyquick fixes? High temp sealnt that I can kinda line in there to fill the small gap?
Old Dec 18, 2005 | 05:13 AM
AbitAvenger's Avatar
http://www.mgchemicals.com/products/106.html
Special Feature High Temperature
Tensile Strength 2.55 MPa (375 psi)
Would that work?
Old Dec 18, 2005 | 05:39 AM
thermal's Avatar
why not just get it resurfaced by a machine shop?
Old Dec 18, 2005 | 05:53 AM
Default Re: (thermal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 905EF8 &raquo;</TD></TR><TR><TD CLASS="quote">
Old Dec 18, 2005 | 06:07 AM
PINKS's Avatar
Default Re: (AbitAvenger)
Ya its my turbo I think that is warped, flange on mani was perfect, its not huge warpage though
Old Dec 18, 2005 | 01:08 PM
PINKS's Avatar
Default Re: Warped Turbo Flange - Will It Leak? .015 Gap - Any HighTemp Sealants? (905EF8)
Old Dec 18, 2005 | 01:23 PM
tony1's Avatar
.015" will definitely leak. You could take it apart and put some sealant on it and reassemble, but if you're going to take it apart, i'd get whatever is not flat resurfaced instead. What manifold is it? I've never seen a turbine housing that wasn't flat, since they're cast.
Old Dec 18, 2005 | 01:25 PM
PINKS's Avatar
Default Re: Warped Turbo Flange - Will It Leak? .015 Gap - Any HighTemp Sealants? (tony1)
The turbo is a used t3 .60/.63, it looks previously machined/ground
Im just gonna try and flatten it as best I can with a straight file and maybe a sheet metal gasket or maybe even tinfoil? I can make
Old Dec 18, 2005 | 01:42 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 905EF8 &raquo;</TD></TR><TR><TD CLASS="quote">Anyquick fixes? High temp sealnt that I can kinda line in there to fill the small gap?</TD></TR></TABLE>
This stuff is awesome.. my buddy uses it on his single digit race car instead of gaskets. (why buy new gaskets all the time?) It comes in a tube for a caulking gun as well..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">For 4-cylinder, turbocharged or high-performance engines. The most advanced, high temperature RTV silicone gasket available. Sensor-safe, low odor, non-corrosive. Superior adhesion. Three times more oil resistant than conventional silicones; eight times more flexible than cut gaskets. Temperature range -75°F to 700°F intermittent; resists auto and shop fluids and vibration.</TD></TR></TABLE>
not sure what you mean by 'line in there'? you'll hav eto take the turbo off and put a decent bead on the flange. I bet it will hold just fine!
Old Dec 18, 2005 | 01:46 PM
SpdFrk's Avatar
Default Re: Warped Turbo Flange - Will It Leak? .015 Gap - Any HighTemp Sealants? (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
not sure what you mean by 'line in there'? you'll hav eto take the turbo off and put a decent bead on the flange. I bet it will hold just fine!</TD></TR></TABLE>
I use this stuff aswell. Works really good.
Old Dec 18, 2005 | 04:15 PM
HamiltonRex's Avatar
Default Re: Warped Turbo Flange - Will It Leak? .015 Gap - Any HighTemp Sealants? (SpdFrk)
I 'third' that.
Good stuff/
Old Dec 18, 2005 | 04:39 PM
beepy's Avatar
Ultra-Copper is good stuff, but not to make an exhaust gasket. I think it is rated at like 400 degrees.
Old Dec 18, 2005 | 05:39 PM
InfamousDC2FI's Avatar
Default Re: Warped Turbo Flange - Will It Leak? .015 Gap - Any HighTemp Sealants? (beepy)
how bout this stuff - 2000 degree stove/gasket cement
http://www.jgstools.com/turbo/index2.html
CoreyR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Ultra-Copper is good stuff, but not to make an exhaust gasket. I think it is rated at like 400 degrees.</TD></TR></TABLE>
its fine ive used it on downpipes and wastegates without a problem.
Old Dec 18, 2005 | 05:43 PM
PINKS's Avatar
Default Re: Warped Turbo Flange - Will It Leak? .015 Gap - Any HighTemp Sealants? (CoreyR)
Anyone else agree that the copper rtv will work with a manifold flange?
Im gonna take the turbo apart tomorrow and file as good as I can, I need something I can pick up locally
Old Dec 18, 2005 | 05:57 PM
CoreyR's Avatar
i guess its worth a try if your not willing to have it milled
Old Dec 18, 2005 | 06:04 PM
locash's Avatar
You do know that they make crush gaskets in the common turbo flange sizes, right?
I'd try that before half of these goofy silicones.
Old Dec 18, 2005 | 06:11 PM
PINKS's Avatar
Default Re: Warped Turbo Flange - Will It Leak? .015 Gap - Any HighTemp Sealants? (locash)
I dont have 2 weeks to wait for this gasket to get to canada
What about tinfoil? That fills the gap, crushes and is metal...
Old Dec 18, 2005 | 06:36 PM
CoreyR's Avatar
do you guys have parts stores up there? they sell metal gasket material in sheets you just trace out the flange on it and use a dremel/tin snips to cut it out.
Old Dec 18, 2005 | 07:02 PM
PINKS's Avatar
They only sell this gasket mat for valve covers or stupid **** I believe
I could use sheet metal, but thats fairly thin and I doubt it would crush
tinfoil seems like it would work though right?
Old Dec 18, 2005 | 07:07 PM
b20vtechb's Avatar
you could buy a thin sheet of copper and anneal it
Old Dec 18, 2005 | 07:12 PM
PINKS's Avatar
Default Re: (b20vtechb)
anyreason why tinfoil wont work?
ive got it apart now, might file it down before I go to bed and assemble with 5-6 layers of tinfoil and squish them ******* down tight with allen bolts n nut
Old Dec 18, 2005 | 07:19 PM
b20vtechb's Avatar
Default Re: (905EF8)
tin foil will melt... i melted the factory exhaust gasket between the manifold and head when it was warped.. i'll have to post a pic of that some people might get a kick out of it
Old Dec 18, 2005 | 08:44 PM
paulzy's Avatar
since you're gonna take it off and apart anyways, why not take the parts to a machine shop to mill flat for a couple of bucks. Might jsut be the flange on the manifold, which would be even cheaper
Old Dec 18, 2005 | 09:59 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">You do know that they make crush gaskets in the common turbo flange sizes, right?
I'd try that before half of these goofy silicones.</TD></TR></TABLE>
hmm.. could you not go to a dealership for this then? if so, what year/make/model?
