finally got my dyno pics!! 300 hp internally stock LS
Old Dec 17, 2005 | 11:20 PM
streetrage's Avatar
Default finally got my dyno pics!! 300 hp internally stock LS
Old Dec 17, 2005 | 11:22 PM
streetrage's Avatar
for all the people who didn't believe me......
Old Dec 17, 2005 | 11:23 PM
vaporboy12's Avatar
Default Re: (streetrage)
nice numbers how much boost? whats your turbo setup?
-Bret
Old Dec 17, 2005 | 11:30 PM
shortyz21's Avatar
Default Re: (vaporboy12)
yeah what engine management.
Old Dec 17, 2005 | 11:37 PM
Boostfed's Avatar
New User
Default Re: finally got my dyno pics!! 300 hp internally stock LS (streetrage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetrage &raquo;</TD></TR><TR><TD CLASS="quote">
Nice #s,had a friend with a stock LS do 299whp 2-3 years ago on a a junkyard turbo kit actually on Hondata Stage 2B which had no Base program at all, my old tuner had to start from scratch on it. Also D-Tuned on here had made 300whp+ on a stock LS motor too
Old Dec 17, 2005 | 11:39 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i did it back in the day and it popped quick, good luck. now Im starting over.
Old Dec 18, 2005 | 05:07 AM
blackeg's Avatar
Default Re: finally got my dyno pics!! 300 hp internally stock LS (HybridcivicLS-T)
hell yea! your power holds nice above 6k too, somewhat atypical of ls's. you must have a big turbo on there
Old Dec 18, 2005 | 05:33 AM
hondaguyef's Avatar
Default Re: finally got my dyno pics!! 300 hp internally stock LS (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">hell yea! your power holds nice above 6k too, somewhat atypical of ls's. you must have a big turbo on there</TD></TR></TABLE>
Or a lil' boost creep . Sick Numbers though, I wish I would have put mine on the dyno in PW/S trim. It made 233whp on 7psi and It was ran on 13psi. at race time. trapped 114mph. LS's are the ****
Phil
Old Dec 18, 2005 | 05:42 AM
thermal's Avatar
D-tuned did that several times......... AEM/EMS
Old Dec 18, 2005 | 06:22 AM
project dc2's Avatar
lawrence tunes hondata. most likeley its a drag only car so always on racegas.
Old Dec 19, 2005 | 11:12 PM
streetrage's Avatar
ya, the car is a drag car, but still has a stock engine. It is always run on c12 race gas, at 18 psi on a turbonetics T3/T04E... Im running the Hondata s200..
Old Dec 20, 2005 | 02:06 AM
Calvinator's Avatar
nice numbers!
Old Dec 20, 2005 | 07:47 AM
VTC_CiViC's Avatar
Default Re: (xtremeazian)
civicflnum1's original LS lasted quite a while making over 300whp, and when it did finally die, the culprit was a shattered oil pump, the motor was internally perfect otherwise. You'd be supprised what an LS can take
Old Dec 20, 2005 | 07:53 AM
igo4bmx's Avatar
my friend made 300 whp and 300 lbs of tq on a stock ls with only a thicker headgasket and arps
Old Dec 20, 2005 | 08:34 AM
emotionisdead's Avatar
Very Emergency!!
Default Re: finally got my dyno pics!! 300 hp internally stock LS (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">lawrence tunes hondata. most likeley its a drag only car so always on racegas.</TD></TR></TABLE>
he tuned my old b20 vtec in my ITR. good guy.
your numbers look very good for an LS. 300hp on stock internals is pretty damn good. post some times when you get them.
Old Dec 20, 2005 | 08:45 AM
ssrcx94's Avatar
friend made 305hp and 270trq on his stock ls 2 weeks ago
Old Dec 20, 2005 | 08:46 AM
LudeToAHatch's Avatar
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">my friend made 300 whp and 300 lbs of tq on a stock ls with only a thicker headgasket and arps</TD></TR></TABLE>
a honda that makes the same amount of HP as it does torque, and stock bore at that?... bs
Old Dec 20, 2005 | 09:06 AM
RyanEJ8's Avatar
Default Re: (LudeToAHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeToAHatch &raquo;</TD></TR><TR><TD CLASS="quote">
a honda that makes the same amount of HP as it does torque, and stock bore at that?... bs</TD></TR></TABLE>
Yeah or he's revving the engine to no more than 4000-5000rpm.
Old Dec 20, 2005 | 09:43 AM
igo4bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeToAHatch &raquo;</TD></TR><TR><TD CLASS="quote">a honda that makes the same amount of HP as it does torque, and stock bore at that?... bs</TD></TR></TABLE>
sorry i was off by a couple HP
http://forums.evans-tuning.com...=1813
Old Dec 20, 2005 | 10:05 AM
http://forums.evans-tuning.com...=1813</TD></TR></TABLE>
impressive!
Old Dec 20, 2005 | 10:11 AM
boostdummy's Avatar
what size turbo with those #'s? t3/t04e .63?
Old Dec 20, 2005 | 10:56 AM
accuracy1's Avatar
Default Re: finally got my dyno pics!! 300 hp internally stock LS (boostdummy)
Tuned one a couple of weeks ago that made 300.2WHP and 248 on the torque. It was a t3/to4e 57trim 63AR 14lbs on pump gas w/ s300 and injectors...other than that it was stock!!!!
Old Dec 20, 2005 | 12:50 PM
RyanEJ8's Avatar
Notice how the hp levels off after torque peaks and then actually drops on the top end? That's why it made so much torque relative to the hp.
Old Dec 20, 2005 | 01:06 PM
adseguy's Avatar
Default Re: (RyanCivic2000)
WOO HOO! Another stock LS in the 300's ! List your setup, it helps others that want to achieve the same goals . Good graph too, kinda look slike mine
Old Dec 20, 2005 | 01:22 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: (adseguy)
badass good #'s
