Driving with bad head gasket
Old Dec 17, 2005 | 09:31 PM
Cuong-nutz's Avatar
Default Driving with bad head gasket
What are the effects to the motor driving around with a bad headgasket? My D15b I just swapped in has a bad headgasket since I'm losing coolant by burning it. I'm blowing white clouds of smoke out the rear tailpipe. Also to confirm this, my plugs' tips have a green coloring to them. Compression on each cylinder is about 180 psi.
Old Dec 17, 2005 | 09:56 PM
Turbo_y8's Avatar
Default Re: Driving with bad head gasket (Cuong-nutz)
why dont you just fix it not costly, pretty simple instead of potentially doing more damage
Old Dec 17, 2005 | 10:05 PM
CALIdelsolSIR's Avatar
Default Re: Driving with bad head gasket (tuck'd98)
just replace it, $75 part and you are good to go.
Old Dec 17, 2005 | 10:08 PM
BoostdRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just fix it not costly, pretty simple instead of potentially doing more damage</TD></TR></TABLE>
I agree. You could cost yourself alot more $$ in the longrun (new engine).
I figure maybe about (from personal experience):
- $45 for the new head gasket
- $90-$100 for new head bolts ($9-$10 ea, and there are 10 of them. It is not recommended to reuse the head bolts but if you have to, then understandable, but stock ones stretch so you can't torque it down correctly).
- And then maybe around $40 for head resurfacing (to ensure you don't blow another head gasket).
Think about it. Another engine will be much more costly.
Old Dec 17, 2005 | 10:20 PM
Average Al's Avatar
wreck the lubracation properties of oil by mixing with coolant.
probably wash out cylinders of oil with the coolant like fuel does.
other than that no big deal
Old Dec 17, 2005 | 11:10 PM
BoostdRex's Avatar
Default Re: (Average Al)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Average Al &raquo;</TD></TR><TR><TD CLASS="quote">wreck the lubracation properties of oil by mixing with coolant.
other than that no big deal</TD></TR></TABLE>
Haha you make it sound like it's no big deal, but of course all of us know that it will just mean another engine if he lets it go very far...
Old Dec 18, 2005 | 06:44 PM
Cuong-nutz's Avatar
Reason I asked was because the history of the motor is unknown and I don't know how long the previous owner drove around like that.
what's the normal compression reading for these motors? Is 180 psi low?
Old Dec 21, 2005 | 05:16 PM
BoostdRex's Avatar
Default Re: (Cuong-nutz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuong-nutz &raquo;</TD></TR><TR><TD CLASS="quote">Reason I asked was because the history of the motor is unknown and I don't know how long the previous owner drove around like that.
what's the normal compression reading for these motors? Is 180 psi low?</TD></TR></TABLE>
180 is not that bad for a stock D-Series...
preludedriva
10
Jul 30, 2007 11:59 AM
saNx
Mar 25, 2007 04:21 PM
WTB AUTO EK
Jan 14, 2006 10:21 AM
JTCdudeman
Sep 29, 2005 05:42 AM
crxpowr91
Aug 21, 2003 01:42 PM
