my JRSC R is tuned..BIG thanks to RLZ
Old Dec 17, 2005 | 08:21 PM
fastvtecCL's Avatar
Default my JRSC R is tuned..BIG thanks to RLZ
First i would like to thank Howard and speed innovations (RLZ) for doing such a great job on tuning my JRSC type R
after about 4 hours on the dyno here's what we got, on 8psi... DYNO JET NUMBERS SHOULD BE AROUND 260whp and 190lbs torque !!!!!!
remember these numbers are on a dyno pack
Old Dec 17, 2005 | 08:26 PM
01ITR#173DC2ning's Avatar
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
Default Re: my JRSC R is tuned..BIG thanks to RLZ (fastvtecCL)
nice #'s......
Old Dec 17, 2005 | 08:29 PM
tommymoose's Avatar
Default Re: my JRSC R is tuned..BIG thanks to RLZ (01ITR#173DC2ning)
Wow, nice
So is that on stock internals???
Old Dec 17, 2005 | 08:33 PM
fastvtecCL's Avatar
Default Re: my JRSC R is tuned..BIG thanks to RLZ (tommymoose)
i have TODA valve springs, but yes the rest is stock
Old Dec 17, 2005 | 08:49 PM
Lifter2012's Avatar
damn bro!!!!!!!! thats niccce, real nice
Old Dec 17, 2005 | 09:00 PM
Mythias's Avatar
I am sorry, but that is one horrrible dyno chart for a JRSC ITR. It should be much smoother. Find yourself a new tuner.
Modified by Mythias at 9:36 AM 12/18/2005
Old Dec 17, 2005 | 10:26 PM
program's Avatar
whoh...
is that your torque curve?
Old Dec 17, 2005 | 10:57 PM
SecretAgent's Avatar
good lord!!! 4 hours and that's the best that they could do???? holy **** that's horrible!! GET IT RETUNED IMMEDIATELY!! the way that torque curve is looking, there are some MAJOR tuning issues, and you could possibly be running of the verge of disaster!
Old Dec 17, 2005 | 11:39 PM
92TypeR's Avatar
FSAE
Default Re: (SecretAgent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mythias &raquo;</TD></TR><TR><TD CLASS="quote">I am sorry, but that is one horrrible dyno chart for a JRSC ITR. It should be much smoother. Find yourself a new tuner. Here is what a chart should look like:</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SecretAgent &raquo;</TD></TR><TR><TD CLASS="quote">the way that torque curve is looking, there are some MAJOR tuning issues, and you could possibly be running of the verge of disaster!</TD></TR></TABLE>
Check out the scale on the torque. Now look at the scale on the other graph. If the scale was the same, the torque curves would look almost identical.
Old Dec 18, 2005 | 12:08 AM
omiehomie's Avatar
Default Re: (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
Check out the scale on the torque. Now look at the scale on the other graph. If the scale was the same, the torque curves would look almost identical. </TD></TR></TABLE>
good eye i would not have spotted that
Bbasso's Avatar
92TypeR, I don't get it...
But then I have not read many dyno charts...
Old Dec 18, 2005 | 12:24 AM
Batoutahell's Avatar
Default Re: (Bbasso)
Even taking scale into account, I've got to agree with Mythias. The tq curve should be increasing steadily at 3000rpm. The initial poster's tq curve is pretty anemic below 5500. His low-end tq would improve dramatically if he'd lower his vtec engagement point to 3000rpm.
Old Dec 18, 2005 | 12:40 AM
98itRspec's Avatar
Default Re: (Batoutahell)
i know for sure someone is not telling the truth about their dyno chart.
Old Dec 18, 2005 | 12:41 AM
98itRspec's Avatar
i agree w/batoutahell.
Old Dec 18, 2005 | 12:59 AM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">92TypeR, I don't get it...
But then I have not read many dyno charts...</TD></TR></TABLE>
The left column is torque, the right is HP. Compare the two charts, the thread starter's chart has 126tq as a minimum, and 153 as maximum. The second chart posted goes from 0 - 300. The scale will affect the shape of the curve. The graph would look very "smooth" if the scale was corrected.
Old Dec 18, 2005 | 05:47 AM
Mythias's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Batoutahell &raquo;</TD></TR><TR><TD CLASS="quote">Even taking scale into account, I've got to agree with Mythias. The tq curve should be increasing steadily at 3000rpm. The initial poster's tq curve is pretty anemic below 5500. His low-end tq would improve dramatically if he'd lower his vtec engagement point to 3000rpm.</TD></TR></TABLE>
I agree, despite the scale of the chart. Also, he should be putting down more than 224whp at 8psi on a dynopack. Mine put down 220whp @ 4.5psi on a dynopack.
Old Dec 18, 2005 | 06:42 AM
fastvtecCL's Avatar
Default Re: (Mythias)
I agree, despite the scale of the chart. Also, he should be putting down more than 224whp at 8psi on a dynopack. Mine put down 220whp @ 4.5psi on a dynopack. </TD></TR></TABLE>
wow calm down guys... first the car was tuned to a safe 11.7 A/F, the car could make more power but for right now i just want it to be safe... 2nd, the boost was slipping from 8psi down to about 6.8psi (from what i was told) after 7500rpms, due too the lower idler pully being messed up along with the belt...
p.s. i will dyno on a dynojet soon
Old Dec 18, 2005 | 07:09 AM
JDM Factor's Avatar
I love the sound of the JRSC's good luck with it. BTW check the belt as often as you can, they seem to break a lot or atleast on my brothers GSR they did.
Old Dec 18, 2005 | 08:31 AM
B18CXr's Avatar
yep, very common on the JRSC setups
Note below: stock B18C1 with "8psi" pulley and AEM EMS, boost tapers off in the higher RPM's
Old Dec 18, 2005 | 09:07 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: my JRSC R is tuned..BIG thanks to RLZ (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">
yep, very common on the JRSC setups</TD></TR></TABLE>
one of my buds had one back in 01, same thing happened. Couldnt really find the cure for it ourselves either. His setup was more around the 10-12 psi setup, after trying a custom made pulley to correct it.
Old Dec 18, 2005 | 11:53 AM
nemesis0104's Avatar
Default Re: my JRSC R is tuned..BIG thanks to RLZ (Stunna BEN)
I"ve been comptemplating buying a JRSC, and see this thread helps out with that decisision, very very nice....
Old Dec 18, 2005 | 12:23 PM
Hooch'n's Avatar
Default Re: my JRSC R is tuned..BIG thanks to RLZ (nemesis0104)
like the turbo better, but glad the car is putting out great power for JRSC.
Old Dec 18, 2005 | 12:31 PM
Shawn C's Avatar
In The Garage
well, the problem with the torque is belt slippage. i've tuned plenty of POS JRSC setups to know. superchargers are parasites. they suck, and i'm sorry for anyone who wasted their money on them.
and BTW- dynopacks show higher numbers than dynojets, so it would make like 210 on a dynojet. tighten your belts, and re-tune. let's see an a/f graph, and i'd love to see the timing table as well
Old Dec 18, 2005 | 04:01 PM
fastvtecCL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nemesis0104 &raquo;</TD></TR><TR><TD CLASS="quote">I"ve been comptemplating buying a JRSC, and see this thread helps out with that decisision, very very nice.... </TD></TR></TABLE>
go for it you'll be very happy
Old Dec 18, 2005 | 04:46 PM
Mythias's Avatar
Default Re: (ShadyEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 &raquo;</TD></TR><TR><TD CLASS="quote">and BTW- dynopacks show higher numbers than dynojets, so it would make like 210 on a dynojet. </TD></TR></TABLE>
IIRC, dynapack's can show higher or lower numbers than a dynojet. It all depends on what you set the length of the run to on the dynapack.
