LS/vtec help
Old Dec 17, 2005 | 07:39 PM
crxsi8's Avatar
Default LS/vtec help
After a long long day swapping we are finally done.
Went to fire up the baby and it won't start!...F**K im pissed?
B18a1 block, JDM b16 head..
was on another car and change over to my crx? started on the other car and ran strong, but when it was put into my crx it cranks but won't start at all? has anyone ever encounter this problem.. ANY help would be GREATLY aprreciated!
Old Dec 17, 2005 | 07:48 PM
C1CRX's Avatar
Traffic signal tech
Default Re: LS/vtec help (crxsi8)
check your grounds go double check the wiring and all the other connections put gas in the car lol j/p check to see if your throwing any codes check everything u can
Old Dec 17, 2005 | 07:54 PM
crxsi8's Avatar
Default Re: LS/vtec help (lvcrx)
check as much as i can? GROUND AS MUCH AS I CAN!...but for some wierd reason even when i took my key off the ignition the lights in the dash is still on? does this mean i have wiring problems..!
Old Dec 17, 2005 | 07:58 PM
95gainfla's Avatar
check to make sure the dizzy cap is on nice and tight and the coils are in good condition.
did you put spark plugs in?
crxsi8's Avatar
Default Re: (95gainfla)
of course why not? but everything is tight?
Old Dec 17, 2005 | 08:45 PM
crxsi8's Avatar
would timing solve anything
Old Dec 17, 2005 | 09:50 PM
crxnj's Avatar
Default Re: (crxsi8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 &raquo;</TD></TR><TR><TD CLASS="quote">would timing solve anything</TD></TR></TABLE>
I doubt it..You said it ran perfect in the other car..
Check to see that you're getting fuel and spark.
Old Dec 17, 2005 | 09:52 PM
95gainfla's Avatar
when you turn to ignition, can you hear the fuel pump kick on?
Old Dec 18, 2005 | 05:38 AM
ryanplayjoint's Avatar
guy, you said the dash lights stay on when you remove the key from the ignition? I guessing that your crx is not an si/hf is that correct? and you did a dual point-to-multi point conversion? like the other guy said listen for the fuel pump and/or leave the ignition in the on position and crack the bolt on the fuel filter line that goes from the filter to the fuel rail. I had this problem when i put and ls/vtec in my 91 civic std. most likely you are not getting fuel and you need to troubleshoot the wiring first before you even think about trying to start the engine.
Old Dec 18, 2005 | 06:54 AM
crxsi8's Avatar
my crx is an si......we checked for spark we put in new spark plugs..........it will crank but the starter chokes when trying to turn the engine.....then a whole bunch of fuel would get dumped out through the header manifold, this i know there is fuel and still it won't start
Old Dec 18, 2005 | 08:40 AM
MonkeyMagic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 &raquo;</TD></TR><TR><TD CLASS="quote">my crx is an si......we checked for spark we put in new spark plugs..........it will crank but the starter chokes when trying to turn the engine.....then a whole bunch of fuel would get dumped out through the header manifold, this i know there is fuel and still it won't start</TD></TR></TABLE>
sounds like a ground issue
Old Dec 18, 2005 | 09:15 AM
crxsi8's Avatar
ECU is throwing no codes..seems like main power to ECU isn't working? had a buddy checked it out and he says electrical problems?
Old Dec 18, 2005 | 09:51 AM
C1CRX's Avatar
Traffic signal tech
check the grounds on the thermostat housing i think that grounds the ECU
Old Dec 18, 2005 | 10:11 AM
ef2_civic's Avatar
Default Re: (lvcrx)
it has to do with something in the electric system
if it ran then it has to do with wiring
injectors and main relay
could be a start
Old Dec 18, 2005 | 03:57 PM
d16vtecx's Avatar
Default Re: (ef2_civic)
i agree with ef2
check your main relay
make sure you are grounded on the trans, thermo housing, and valve cover
Old Dec 18, 2005 | 04:07 PM
crxsi8's Avatar
EXCELLENt..Thanks for everyones help? IT RUNS!
Old Dec 18, 2005 | 04:11 PM
C1CRX's Avatar
Traffic signal tech
what was it
bassplayer
Dec 29, 2009 01:49 PM
SeanWard
Feb 21, 2009 04:09 PM
ef9king
Feb 16, 2006 12:03 AM
crxracer2006
Sep 22, 2005 11:46 AM
tradesalot
Sep 15, 2004 06:33 AM
