EK bogging at WOT help?
Old Dec 17, 2005 | 05:45 PM
sporty240's Avatar
Default EK bogging at WOT help?
so I got this 96 ek with a b18b swap the car runs alright then at 100% throttle it bogs like I hit a brick wall. It runs pretty good at all gear/Rpm until I floor it, when it bogs I let go of the gas just a little (99% throttle) and goes to normal, so basically it only bogs a 100% and not 99%-1%, no CELs either
anybody know what it could be?
Old Dec 17, 2005 | 05:47 PM
Ricey McRicerton's Avatar
Default Re: EK bogging at WOT help? (sporty240)
What injectors are you using? I was using some 240cc injectors before I found out that the y7 originally had 180cc units and it would do something similar to this.
Old Dec 17, 2005 | 05:57 PM
sporty240's Avatar
Default Re: EK bogging at WOT help? (Ricey McRicerton)
im not sure I just got the car, is there any way to find out the difference? like a number on them or something?
Old Dec 17, 2005 | 08:45 PM
ej0513's Avatar
check you TPS. at WOT it should be 5v i believe.. im not too sure.. can anyone chime in on this?! this maybe your problem.
Old Dec 17, 2005 | 11:10 PM
JibOnALib's Avatar
Default Re: (ej0513)
I had a similiar problem when i swapped a gsr in my car, all i did was new plug wires/cap and rotor and it fixed it, sounds like the same problem.
Old Dec 19, 2005 | 05:21 PM
sporty240's Avatar
Default Re: (JibOnALib)
alright ima try this stuff and see what happens..
Dursty_EK
Jan 16, 2012 09:01 PM
jdmdreamz414
19
Jul 19, 2011 12:09 PM
w1ckedboy504
Jan 18, 2010 12:58 AM
MonsterB20Ek
Jun 18, 2007 04:04 PM
Benny Z
Jul 1, 2003 05:59 PM
