Car wont crank over sometimes. help. no search found.
Old Dec 17, 2005 | 11:53 AM
PaImportTuner's Avatar
Default Car wont crank over sometimes. help. no search found.
every morning i go to turn on my car it doesn't go on. i have to compression start it (push the car and pop clutch). i notice when the outside temperature is 38-40 degrees out it turns on perfectly without a push. i notice when its 20 degrees it doesnt turn on.
after compression starting it in the 15-20deg weather it runs and idles fine. when i drive it for 5-10 minutes and park and turn car off. wait a few minutes and try to turn it on again it turns on again with key, no compression start needed.
also when i mean the car doesnt turn on i mean its not cranking over. i tested my alternator and battery found out the battery is bad in 1 cell. well since i got the battery less than a year ago they switched it out for a new one at Autozone.
now sure if its the starter, main relay. ecu or the new battery. anyone else have this problems when its really cold out?
my friends crx si does it too. last winter i didnt have this problem. we both work on cars and dont know whats up it could be something very small and simple that we are overlooking.
Old Dec 17, 2005 | 03:10 PM
Default Re: Car wont crank over sometimes. help. no search found. (PaImportTuner)
bumpity bump bump
Old Dec 17, 2005 | 05:54 PM
jpciii's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaImportTuner &raquo;</TD></TR><TR><TD CLASS="quote">
You can add ignition switch to that list.
Most likely it is the ECU. The reason they go bad is because solder joints on the board start to go bad... after years of extreme temperature changes. It is common for ecu problems to be intermittant (sp?) It can be very difficult to detect which solder joint(s) have started to go, so just re-solder all of them.
Old Dec 18, 2005 | 04:31 AM
well i disconnected the ecu and had it laying next to me on the floor of a warm house. went out a few minutes ago and no crank. any other things?
Old Dec 22, 2005 | 03:44 PM
smokey2.0's Avatar
try another starter, and see what happens!
NiKKa NiKKy
Jun 30, 2022 09:59 PM
SwiftTypeR
Jan 3, 2008 06:46 AM
Muckman
Oct 4, 2006 08:20 AM
silverdragon277
Aug 19, 2006 10:42 AM
ahcjar103
Dec 9, 2001 11:37 PM
