password jdm whale cock on 4th gen lude
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI »</TD></TR><TR><TD CLASS="quote">
Yes it will fit, but it does require some modification.</TD></TR></TABLE>
Yeah, I thought you had to relocate your battery for it to work?
Not for sure what all is nessicar.
As I understand it you can rotate the battery 90*. Or get a smaller battery. There is a clearance issue with the AC Lines. I believe the ones that go over the transmission.
If you do rotate the battery you have another AC Line clearance issue w/ the line that is next to the battery.
Other then that from what I understand you will get improved throttle response over most if not all intakes on the market, but the top end isn't as strong as a CAI(there is some debate on the last part).
let mags chime in, but he might even sell it. I think he has bigger plans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ »</TD></TR><TR><TD CLASS="quote">
Yeah, I though I remembered him posting something about getting rid of it
you will have to bend the little ac line and rig up the overflow reservoir to move the battery 90 degrees sideways, and then move some of the engine harness plugs and probably bend the ac lines underneath it
i just moved my battery to the trunk, it was hitting the filter and ruining it....
B2FiNiTY
Oct 13, 2003 08:03 PM
