No PS: How Hard Is it to Turn
Old Dec 17, 2005 | 08:48 AM
vinuneuro's Avatar
Default No PS: How Hard Is it to Turn
How are is it to turn at low speeds in the Prelude without power steering?
Old Dec 17, 2005 | 08:52 AM
The_Sober's Avatar
Default Re: No PS: How Hard Is it to Turn (vinuneuro)
not easy. there's a guy with a thread about it, you should ask him
Old Dec 17, 2005 | 08:59 AM
BB4's Avatar
BB4
depends how strong your forearms are
Old Dec 17, 2005 | 10:13 AM
M@'s Avatar
M@
I read that if you looped the PS lines its was alot easier then if your PS just crapped out.
Old Dec 17, 2005 | 10:22 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote"> How are is it to turn at low speeds in the Prelude without power steering? </TD></TR></TABLE>
Low speeds?....hard. If my car is not moving I have to use both hands to turn the wheel, but the more you start moving the easier it is. After about 10mph it's very driveable with one hand.
Old Dec 17, 2005 | 10:30 AM
PreludeSi94's Avatar
Default Re: No PS: How Hard Is it to Turn (Hawkze_2.3)
IMO: its actually easier than most cars... but then again depends on your strength you would get used to it. I also like the handling after i took the ps pump out.
Old Dec 17, 2005 | 11:02 AM
matix's Avatar
Default Re: No PS: How Hard Is it to Turn (PreludeSi94)
Yea it def takes some strength when trying to park. Once your moving its easy. I love the way it feels when cornering fast.
Old Dec 17, 2005 | 11:19 AM
vinuneuro's Avatar
Default Re: No PS: How Hard Is it to Turn (matix)
I'm looking at a Prelude in which the ps was removed. If I get it and decide I do want it, how laborious is it to get back in there?
Old Dec 17, 2005 | 11:25 AM
i_kick_turtles's Avatar
It depends on if the whole system was removed or just the pump. If the whole system was removed you will have a heck of a time reaching the rack with the engine in. At the very least, you would have to remove the intake manifold to get it.
Old Dec 17, 2005 | 11:37 AM
Under_Pressure's Avatar
Default Re: No PS: How Hard Is it to Turn (I R Tylor)
stop being a girl! its not hard to drive without PS plus u get bigger arms!
Old Dec 17, 2005 | 12:01 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I R Tylor &raquo;</TD></TR><TR><TD CLASS="quote">It depends on if the whole system was removed or just the pump. If the whole system was removed you will have a heck of a time reaching the rack with the engine in. At the very least, you would have to remove the intake manifold to get it.</TD></TR></TABLE>
Very true, it will depend on how much was removed. Ther are lines from the pump to the steering rack to the VSS to the reservior plus several sensors an such.
Old Dec 17, 2005 | 12:51 PM
skimeast1982's Avatar
It's not hard to drive with no power steering...it just feels "unsafe" ... theres so much play in the wheel it just feels like your going to take a corner too fast, not crank the wheel hard enough and fly straight off into a ditch or tree haha. Getting over the feeling of having two flat tires up front takes a little getting used to.
I used to drive an 89 Dodge RamCharger ( SUV ) ...with some sloppy *** steering and the feeling is the exact same now in my prelude
Old Dec 17, 2005 | 06:01 PM
Dongoesby's Avatar
Default Re: No PS: How Hard Is it to Turn (skimeast1982)
I agree it feels unsafe. I drove once before. It took me a while to get used to it, especially when you making a U turn, it was a very painful experience, but once when your car is moving, it is easier to turn. But when you are making a turn fast, the wheel gets back so quickly, and it would give you shock and yes, it is quite unsafe for me.
When I get back to PS, it feels much better to turn and daily drive, but ironically, I quite like driving without PS, because it feels more precise whiling turning.
Old Dec 17, 2005 | 06:16 PM
mgags7's Avatar
you guys would learn to slightly gas it to help turning when you normally wouldnt....its not too bad, really...
and it shouldnt feel too sloppy....i usually like ps though....i drive a lot....
Old Dec 17, 2005 | 07:37 PM
Thanks knightsport!'s Avatar
I'm a Jackass
Default Re: (mgags7)
its hard in the beginning but you get used to it. i wish i had my ps. ***** a bitch when you need to park. i guess you just gotta man up and do the damn thang!
Old Dec 17, 2005 | 07:58 PM
mgags7's Avatar
Default Re: (dirrtybirdy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirrtybirdy &raquo;</TD></TR><TR><TD CLASS="quote">its hard in the beginning but you get used to it. i wish i had my ps. ***** a bitch when you need to park. i guess you just gotta man up and do the damn thang!</TD></TR></TABLE>
8whp+ is worth it for some people....i may do it if i can get together a good breather/catch reservoir setup....
wrXtian
Suspension & Brakes
Sep 18, 2005 01:25 AM
mugen92acintls
Feb 4, 2004 04:05 PM
BoostedSixthGen
Aug 12, 2003 03:33 AM
Chairman Kaga
Feb 13, 2003 11:36 AM
Gangsta Accord
Jun 25, 2002 09:41 AM
