h22 swap?
I'm responding b'cuz I don't like seeing anyone orphaned in here (I'm a soft touch).
You may find a lack of responses because the vast majority of H22 swap are performed on thru '97 Accords and Civics. There may not be enough people doing H22 swaps in 6th Gen Accords yet. (for varying reasons I guess).
I'd suggest you "bump" the thread occasionally to keep the question current, and check back occasionally.
P
P
now, as far as 6gen accords, Im not too sure an h22 swap has been done yet. You might be the first to play around with it... I did find a little something today about swapping the h22 into a 4thgen accord. (Hey, it helps me out.) Read a little into it, it might have something in there for ya.
Heres the site:
http://www.sportcompactcarweb....ybrid/
Heres the site:
its nothing new, and relatively easy to do. Here is some topics to help you out.
https://honda-tech.com/zerothread?id=473019 - lays out detailed instructions
with some pics for 6th gen h22 swap
https://honda-tech.com/zerothread?id=689185 - info on motor mounts for 6th
gen h22 swap
https://honda-tech.com/zerothread?id=539099- some general discussion on
wiring (could help you some)
https://honda-tech.com/zerothread?id=936880- a thread with those three links
above in it and some info
https://honda-tech.com/zerothread?id=793211 - don't know if your h22 is obd2
or 1 but heres some dizzy problems for one of the obd's cant remember which one
gen h22 swap
low13da9
Mar 18, 2012 09:59 PM
