EK Civic with B16, need new gauges!
Whats up everyone, i have a '99 Civic Hatchback with a swapped in B16A2, i also have the 96-00 Civic EX gauge cluster install so i could have the tach in my car, but now the rpms from the motor do not mathc that of the Ex cluster, what can i do to have a cluster that will fit my civic and show me the correct RPMs.
Should i install a DOHC Del Sol cluster, Civic Si cluster, or what!
Civic Si cluster, CTR cluster, SiR cluster. those are your options since u have the EX cluster already. the Del Sol VTEC cluster wont fit unless u fab it to fit just like any cluster
so the SiR would that be a 96-00 or a 92-95...i'm guessing the 96-00 would be the best...and is there any way to get one that is converted from KPH to MPH?!
yea but still stock clusters like that wont show the exact RPM your motor is really at.. I have a VAFC and a Si cluster in my Ek and the Cluster is always like 200 rpms off.. The VAFC is more accurate or somthing u dirrectly split into your ECu with will show the most accurate.
