99 prelude with odb1 94 h22 ecu, which injectors 345cc? help.
i have a 99 prelude and currently running with odb1 ecu chipped. it runs like crap because odb2 injectors are 290 whereas odb1 injectors are 345. So, can i use odb1 injectors and what do i need to make them work. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic »</TD></TR><TR><TD CLASS="quote">resistor box</TD></TR></TABLE>
So if I have a P13 obd1 and i had a resistor box for the h23 (240cc) injectors, would this one work with the (345cc)??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">290cc injectors at 50+ psi flow the sme as 345cc at 36-40 psi.</TD></TR></TABLE>
how about 00 h22a4 engine with 290cc @ 50psi would be compatible with odb2 96 ecu vtec? the 96 odb2 ecu has 345cc i believe.
