Question about white smoke
Old Dec 17, 2005 | 06:31 AM
Nuke209's Avatar
Default Question about white smoke
I did search around, seemed like others had headgasket problems
I have a b16 and my car doesn't smoke up alot of white smoke, but white smoke does come out of my exhaust and i'll probably drive it for like 5 minutes and it stops smoking
is this normal? i think i was burning oil because i had to top it off (half a quart) every once in a while?
a friend told me, could be my valve seals...
so any help? thanks in advance
Old Dec 17, 2005 | 07:25 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Question about white smoke (Nuke209)
vtec engines use oil it is normal. as for white smoke, during the winter it is not uncommon for it to smoke white because if water vapor in the exh. if you are worried, do a compression and leakdown test. but odds are youll be ok.
Old Dec 17, 2005 | 07:40 AM
turbotime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nuke209 &raquo;</TD></TR><TR><TD CLASS="quote">white smoke does come out of my exhaust and i'll probably drive it for like 5 minutes and it stops smoking</TD></TR></TABLE>
thats normal, its condensation, a natural byprod. of combustion, and its visiblilty decreases as your engine warms up (thats why it stops after 5 min)
unless is smells really sweet like burning coolant, and you see your coolant levels dropping unexlplainably, then its normal.
Old Dec 17, 2005 | 10:27 AM
Nuke209's Avatar
well, five minutes of driving, i can have it idling for like 15-20 minutes, drive it and it'll still smoke for like 5 minutes, then begins to stop smoking as I drive
also, another question, my car use to warm up quick, takes like 10 minutes and the temp gauge would be almost half way, now, after 15-20 minutes, it barely moved...any reason why?
Old Dec 17, 2005 | 10:41 AM
96dxpower's Avatar
Default Re: (Nuke209)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nuke209 &raquo;</TD></TR><TR><TD CLASS="quote">well, five minutes of driving, i can have it idling for like 15-20 minutes, drive it and it'll still smoke for like 5 minutes, then begins to stop smoking as I drive
also, another question, my car use to warm up quick, takes like 10 minutes and the temp gauge would be almost half way, now, after 15-20 minutes, it barely moved...any reason why?</TD></TR></TABLE>
winter season???
Old Dec 17, 2005 | 10:52 AM
Nuke209's Avatar
oh yea, my bumper kinda looks like it gets dirty from the smoke, like little specs of oil or dirt or something also
Old Dec 18, 2005 | 04:09 AM
EK45VTi's Avatar
Maybe your thermostat stuck open... that's why your needle is not moving... even in coldest temperatures my car warms up (needle gets halfway to hot) in about 5 minutes of driving (3-5 miles)
As for the dirty bumper, just clean it... it is also normal... it CANNOT BE CLEAN since exhausts come from the muffler and they are not clean... you can avoid "the dirty bumper" by fitting some exhaust tip that will stick a bit out of the bumper...
Like this:
Old Dec 18, 2005 | 08:16 AM
JeffBro's Avatar
Yeah I have seen a few cars with blown headgaskets and usually the white smoke gets worse as it warms up and it doesnt stop smoking. Also it has a highly distinct smell.
Old Dec 18, 2005 | 09:21 AM
young noob's Avatar
Default Re: (JeffBro)
its normal, just go outside when its really cold, and exhale, its white, its that or your buring coolant, check your coolant levels
Old Dec 18, 2005 | 09:28 AM
frog169's Avatar
see i have a b16 as well, my car would be warmed up and i could still see little white smoke, took it to a shop he smelt it and said it was fine so i figgured hey its normal. i hear as long as its not black its good but if its a ton of white its norm a semi easy fix
dailyekhatch
Aug 15, 2011 06:45 AM
XxJDMugenCivicxX
Feb 5, 2007 03:21 PM
powwie
Apr 20, 2006 08:58 PM
redDAinteg
Jan 9, 2006 04:57 PM
bitr364
Mar 10, 2003 06:53 AM
