How do YOU cut the hole in the manifold for the wastegate?
Ive done this several times, and all times ive done it a very ghetto way. Since I usually make the wastegate tube come out of the collector, I need to make a hold in it perpendicular to flow(relatively) How do you make this hole? I typically use a grinding wheel and grind a hole...then use a carbide bit to clean it up. Using a hole saw never seemed to work since I could never get the collector to "stay" in the vice.
not sure on what you may have access to interms of tools but usually a tube vise, which has opposing V jaws or just a V block can hold your work peice so you wont get chatter and other dangerous things going on. a good bimetal hole saw well work as long as your going slow (both rpm and feed), using coolant, and its in a larger drill press or bridge port of some kind. there should be near zero clean up work when its fixtured properly, the one peice is a straight bore, the other notched to the o.d. of its mate.
use a nice hole saw for metal such as a Lenox, use a nice press that you can turn the speed down on. Most people run 3X the drill speed they should be. Lastly, keep the saw cool. Some use cutting oil, I actually have a squirt bottle just filled with water, spray the saw when youre cutting the hole. My technique is when I see steam then the saw is too hot so I up the spraying. That is a good method to throttle how much you spray. Done properly a hole for a WG in sch40 pipe should take around 5 min to cut tops and I usually get 3-4 manifolds per saw.
HTH
-bill
HTH
-bill
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~RTErnie~ »</TD></TR><TR><TD CLASS="quote">how much did they charge you? Im just curious</TD></TR></TABLE>
$20-$30? (CDN).. I had a few other things done at the time so I can't give you an exact price.. they can clamp it down and mill a nice clean hole in it in 20-30min tops.
I forget to mention that i ruined hole saw I had laying around before I took it to a machine shop..
If i had a full size drill press and good clamps/vice I'm sure I would have had better luck - but stainless (sch 40!!) is very hard on any cutting tools unless they are top knotch.
what kind of hole saw are you using? The one i have i can cut sch10 in about 5mins with a cordless drill. Only reason it takes 5mins is becasuse i stop and spray lube on it. wont a plasma cutter work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88_DX »</TD></TR><TR><TD CLASS="quote">what kind of hole saw are you using? The one i have i can cut sch10 in about 5mins with a cordless drill. Only reason it takes 5mins is becasuse i stop and spray lube on it. wont a plasma cutter work? </TD></TR></TABLE>
plasma = dirty. it sprays **** all over the inside of the collector. looks like crap afterwards.
im suprised to hearof people having problems cutting holes in collectors. im lucky to have a decenly sized drill press to my acces, this is what i use, along with a hole saw bought from home depot(1 5/8) i think is the size we use. i had a friend hold the manifold on the work area of the drill press, and i man the lever to lower the bit. it took all of 5 minutes to cut that bish.
jdmcivic2fast
Welding / Fabrication
Nov 8, 2011 02:41 PM
Samuels
Feb 7, 2007 07:55 PM
Justin Olson
29
Sep 15, 2006 04:41 AM
BoostedEgHatchFl
Oct 25, 2005 03:15 PM
