spark plug gapping
Old Dec 16, 2005 | 11:16 PM
asianalbutt's Avatar
Default spark plug gapping
ok i have read my accord owners manual for the gapping. but thats just facotry gapped plugs. and i want to gain a lil more power from the gapping. i was wondering wat do u ppls have ur spark plugs gapped at??? which rating is better???
Old Dec 17, 2005 | 07:23 AM
dodge-honda's Avatar
Default Re: spark plug gapping (asianalbutt)
Go by Honda's specs only or you can have mis fires down the road. It would be different if you had an MSD or similar ignition system with real hot plugs but with a normal system you would be only hurting things to screw with the gap.
Old Dec 17, 2005 | 10:17 AM
hmmmmmm alright then.
Old Dec 17, 2005 | 11:22 AM
i_kick_turtles's Avatar
Default Re: (asianalbutt)
I would leave them at the stock gap. But definately index them.
Old Dec 17, 2005 | 05:34 PM
deserthonda's Avatar
they are supposed to be gapped at .040--.044 do them always at the lower end because as they wear down the gap will get bigger
Old Dec 18, 2005 | 11:13 AM
are these for stock sparkplugs???
Old Dec 18, 2005 | 05:55 PM
Heat's Avatar
For what it's worth and knowing that this is for a different generation, my '99's owner's manual specifies 0.04".
Old Dec 19, 2005 | 05:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asianalbutt &raquo;</TD></TR><TR><TD CLASS="quote">are these for stock sparkplugs???</TD></TR></TABLE>
yes ... actually i was a tiny off ,, gap should be .039-.043....including yours Heat..
so set it at .039 cause like i said as they wear gap gets wider
Old Dec 19, 2005 | 09:11 AM
hondadude's Avatar
Default Re: (deserthonda)
Interesting side note the NGK plugs have the gap in mm at the end of the part number bpr5ey11 the '11' means 1.1 mm
Midori Green
26
Nov 25, 2006 05:39 PM
Jcup315
Apr 18, 2005 06:08 PM
hondaeg8
10
Feb 4, 2005 04:37 PM
GG-SquadDB
Jan 31, 2005 07:17 PM
X2BOARD
Jul 15, 2004 11:37 AM
